Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this uncommon header out of the common header.
This is a network function so let's move it into that header.
This is only used by a few files so it should not be in the common header.
Move it out.
The SBx81LIFKW boards connect to the internal chassis management network
via a Marvell 88e6097 L2 switch. The chassis connections are direct
serdes on ports 8 and 9 with a RGMII interface on port 10 connected to
the CPU MAC.
For debugging purposes ports 0 and 1 are also taken out to headers on
the board. Because the debug interfaces are sometimes connected to with
straight ribbon cables we need to run them at 10Mbps.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This is a series of line cards for Allied Telesis's SBx8100 chassis
switch. The CPU block is common to the SBx81GS24a, SBx81XS6, SBx81XS16
and SBx81GT40 cards collectively referred to as SBx81LIFKW in u-boot.
