path: root/board/alaska
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-11-07board/alaska/flash.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: flash.c: In function 'flash_erase': flash.c:409:21: warning: variable 'last' set but not used [-Wunused-but-set-variable] flash.c:408:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data': flash.c:669:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data_block': flash.c:709:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-10powerpc: Move duplicated BAT defines to mmu.hBecky Bruce
The BAT fields are architected; there's no need for these to be in cpu-specific files. Drop the duplication and move these to include/asm-ppc/mmu.h. Also, remove the BL_xxx defines that were only used by the alaska board, and switch to using the BATU_BL_xxx defines used by all the other boards. The BL_ defines previously in use had to be shifted into the proper position for use, which was inefficient. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2008-07-10Fix some more print() format errors.Wolfgang Denk
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Remove obsolete mpc8220 linker scriptsGrant Likely
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-07-30Implement h/w sector protection status synchronization at boot.Wolfgang Denk
The code is provided for, and was tested on, the Yukon/Alaska and PM520 boards only. A bug in flash_real_protect() for the Yukon board was fixed by adding a function that tells if two banks are on one flash chip.
2005-05-16Add PCI support for Sorcery board.wdenk
Code cleanup (especially Sorcery / Alaska / Yukon serial driver).
2005-04-05Add support for MPC8220 based "sorcery" board.LABEL_2005_04_05_2345wdenk
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
