path: root/board/ait
2014-07-01Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-06-19mtd: nand: davinci: add header file for driver definitionsKhoronzhuk, Ivan
The definitions inside emif_defs.h concern davinci nand driver and should be in it's header. So create header file for davinci nand driver and move definitions from emif_defs.h and nand_defs.h to it. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> [trini: Fixup more davinci breakage] Signed-off-by: Tom Rini <trini@ti.com>
2014-05-29Add cli_ prefix to readline functionsSimon Glass
This makes it clear where the code resides. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29move CLI prototypes to cli.h and add commentsSimon Glass
Move the CLI prototypes from common.h to cli.h as part of an effort to reduce the size of common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Remove unnecessary use of hush header fileSimon Glass
Some files include hush.h but don't actually use it. Remove this where possible. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-12kbuild: rename SRCTREE to srctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used for instead. This commit renames SRCTREE to srctree and deletes the defition of SRCTREE. Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c, doc/DocBook/Makefile should be keep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-26arm: make _end compiler-generatedAlbert ARIBAUD
This prevents references to _end from generating absolute relocation records. This change is binary invariant for ARM targets. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-09-06cam_enc_4xx: Move CONFIG_SPL_PAD_TO to a config headerMasahiro Yamada
For most boards which define CONFIG_SPL_PAD_TO, it is defined in config header files. Currently, there exists only one exception, cam_enc_4xx board. This patch moves CONFIG_SPL_PAD_TO definition from board/ait/cam_enc_4xx/config.mk to include/configs/cam_enc_4xx.h. With this modification, we can delete a glue code in the top level config.mk: ifneq ($(CONFIG_SPL_PAD_TO),) CPPFLAGS += -DCONFIG_SPL_PAD_TO=$(CONFIG_SPL_PAD_TO) endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Heiko Schocher <hs@denx.de>
2013-06-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-06-21remove all references to .dynsymAlbert ARIBAUD
Discard all .dynsym sections from linker scripts Remove all __dynsym_start definitions from linker scripts Remove all __dynsym_start references from the codebase Note: this touches include/asm-generic/sections.h, which is not ARM-specific, but actual uses of __dynsym_start are only in ARM, so this patch can safely go through the ARM repository. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-04-14cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
This target wants to check full SPL size, BSS included. Remove CONFIG_SPL_MAX_SIZE definition and instead define CONFIG_SPL_MAX_FOOTPRINT. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-12Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/video/exynos_fb.c
2013-04-12arm: Make all linker scripts compatible with per-symbol sectionsBenoît Thébaudeau
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for future changes in order to create symbol-specific sections in common .S files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-29menu: Add support for user defined item choice functionPali Rohár
Selecting menu items is currently done in menu_interactive_choice() by reading the user input strings from standard input. Extend menu_interactive_choice() to support user defined function for selecting menu items. This function and its argument can be specified when creating the menu. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Remove linker lists (LGAs) from SPL linker scriptsAlbert ARIBAUD
Many SPL linker scripts needlessly include linker lists (aka LGAs). Remove them whenever possible; keep it only in the seven am335x_evm variants (am335x_evm, am335x_evm_uart[1-5], am335x_evm_spiboot), where there is actual content in output section .u_boot_list. This commit keeps all u-boot.bin and u-boot-spl.bin in ARM targets byte-identical. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-12-19spl: Change PAD_TO to CONFIG_SPL_PAD_TOScott Wood
This was already used by some SPL targets, and allows the pad amount to be specified by board config headers rather than only in makefile fragments. Also supply a pad-to of zero if the variable is undefined. It works without this, but this avoids relying on undocumented behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-03-27ARM: davinci: fixes for cam_enc_4xx boardHeiko Schocher
- change CONFIG_ENV_RANGE to contain 2 nand erase blocks, one for bad block reserve. - remove from the envvariable "img_writeramdisk" the ubifsmount command, as it is not needed. - erase the hole mtd partition containing u-boot - save environment variable "dvn_app_vers" and "dvn_boot_vers" only after installing the new image. changes requested from Marek Vasut: - arm, davinci: fix eldk-4.2 warnings for cam_enc_4xx board - get rid of run_command2 usage needed since patch: commit 009dde1955583e306cf904c864068f3acb0db499 Author: Simon Glass <sjg@chromium.org> Date: Tue Feb 14 19:59:20 2012 +0000 Rename run_command2() to run_command() is now in mainline. - add CONFIG_SPL_LIBGENERIC_SUPPORT support - remove CONFIG_CMD_PXE support - fix warning: cam_enc_4xx.c: In function 'menu_handle': cam_enc_4xx.c:609: warning: dereferencing type-punned pointer will break strict-aliasing rules - fix error: arm-linux-ld: u-boot-spl: Not enough room for program headers, try linking with -N Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <tom.rini@gmail.com> Cc: Fletzer Martin <Martin.Fletzer@ait.ac.at> Cc: Wolfgang Denk <wd@denx.de>
2012-03-27cam_enc_4xx: Rename 'images' to 'imgs'Tom Rini
To avoid a conflict with common/cmd_bootm.c's 'images' (which is exposed as part of the Linux SPL series), rename the board-specific 'images' to 'imgs'. Cc: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12arm, davinci: cam_enc_4xx board updatesHeiko Schocher
- CONFIG_SYS_MMC_ENV_DEV, needed if environment on mmc - wait for 1 second timer in board_late_init() only, if timer is running. - add UBI/UBIFS support - add FIT images support - menu support - U-Boot max size now 0xa0000 - SPL now Block 0 page 0 - new MTD partitioning 0x00000000 SPL 0x00020000 UBL-Header 0x00040000 UBL-Header 0x00060000 UBL-Header 0x00080000 UBoot (0xa0000(U-Boot length) + 0x60000(3 spare blocks)) 0x00180000 ENV- Variablen (1) 0x001a0000 ENV- Variablen (2) 0x001c0000 ENV- Variablen (reserved for Bad Block) 0x001e0000 ENV- Variablen (reserved for Bad Block) 0x00200000 UBI-Device UBI Volumes: „default“: contain environment-default values „rootfs1“: UBIFS root-fs (1); contain linux kernel image „rootfs2“: UBIFS root-fs (2); contain linux kernel image „data-ro“: UBIFS data (read only) „data-rw“: UBIFS data (read/write) - new environment variables: - app_reset (this is only passed per cmdline to linux) - dvn_app_vers string from ramdisk description contained in the FIT image - dvn_boot_vers string from ubootimage description contained in the FIT image - saveparms, restoreparms, restoretmpparms, savetmpparms helper for saving network parameter. - ubiargs set ubi kernel cmdlinargs for booting with a ubifs rootfs - ubi_ubi boot with reading kernel image from ubifs, and use a ubifs as rootfs Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2011-12-06arm, davinci: move misc function in arch treeHeiko Schocher
move the board/davinci/common/misc.c file to arch/arm/cpu/arm926ejs/davinci/misc.c, so all davinci boards can use this functions. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Christian Riesch <christian.riesch@omicron.at>
2011-11-03arm, davinci: add cam_enc_4xx supportHeiko Schocher
- DM368 SOC - booting with spl not with UBL from TI - before loading u-boot from NAND into RAM, test the RAM with the post memory test. If error is found, switch all LEDs on and halt system. - SPI Flash Dataflash Typ: M25PE80 - Ethernet DM9161BI - MMC - USB Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
