This has not been converted to Generic Board, so should be removed.
(See doc/README.generic-board for details.)
Acked-by: Heiko Schocher <hs@denx.de>
Commit 41623c9 'arm: move exception handling out of start.S files' missed some
linker scripts. Hence, some boards no longer had exception handling linked since
this commit. Restore the original behavior by adding the .vectors section to
these linker scripts.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
This prevents references to _end from generating absolute
relocation records.
This change is binary invariant for ARM targets.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
[trini: Fixup common/cmd_io.c]
Discard all .dynsym sections from linker scripts
Remove all __dynsym_start definitions from linker scripts
Remove all __dynsym_start references from the codebase
Note: this touches include/asm-generic/sections.h, which
is not ARM-specific, but actual uses of __dynsym_start
are only in ARM, so this patch can safely go through
the ARM repository.
Tested-by: Lubomir Popov <lpopov@mm-sol.com>
Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
This target wants to check full SPL size, BSS included.
Remove CONFIG_SPL_MAX_SIZE definition and instead define
CONFIG_SPL_MAX_FOOTPRINT.
Let all ARM linker scripts handle properly -ffunction-sections
and -fdata-sections. This will be useful for future changes in order to create
symbol-specific sections in common .S files.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Many SPL linker scripts needlessly include linker lists (aka LGAs).
Remove them whenever possible; keep it only in the seven am335x_evm
variants (am335x_evm, am335x_evm_uart[1-5], am335x_evm_spiboot),
where there is actual content in output section .u_boot_list.
This commit keeps all u-boot.bin and u-boot-spl.bin in ARM targets
byte-identical.
Add section for the linker-generated lists into all possible linker
files, so that everyone can easily use these lists. This is mostly
a mechanical adjustment.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
- change CONFIG_ENV_RANGE to contain 2 nand erase blocks,
one for bad block reserve.
- remove from the envvariable "img_writeramdisk" the
ubifsmount command, as it is not needed.
- erase the hole mtd partition containing u-boot
- save environment variable "dvn_app_vers" and "dvn_boot_vers"
only after installing the new image.
changes requested from Marek Vasut:
- arm, davinci: fix eldk-4.2 warnings for cam_enc_4xx board
- get rid of run_command2 usage
needed since patch:
commit 009dde1955583e306cf904c864068f3acb0db499
Author: Simon Glass <sjg@chromium.org>
Date: Tue Feb 14 19:59:20 2012 +0000
Rename run_command2() to run_command()
is now in mainline.
- add CONFIG_SPL_LIBGENERIC_SUPPORT support
- remove CONFIG_CMD_PXE support
- fix warning:
cam_enc_4xx.c: In function 'menu_handle':
cam_enc_4xx.c:609: warning: dereferencing type-punned pointer
will break strict-aliasing rules
- fix error:
arm-linux-ld: u-boot-spl: Not enough room for program headers,
try linking with -N
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Fletzer Martin <Martin.Fletzer@ait.ac.at>
- DM368 SOC
- booting with spl not with UBL from TI
- before loading u-boot from NAND into RAM, test
the RAM with the post memory test. If error
is found, switch all LEDs on and halt system.
- SPI Flash
Dataflash Typ: M25PE80
- Ethernet DM9161BI
- MMC
- USB
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
