path: root/board/afeb9260
2011-06-21Build fix/update of AFEB9260Sergey Lapin
Make AFEB9260 build again. Based on fix for AT91SAM9260EK. Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-01at91sam9260/afeb9260: Fix SPI initializationAlbin Tonnerre
Commit 7ebafb7ec1a0285af8380623c009576f92583b98 introduced a mistake in the spi init function call for those boards. This patch fixes this. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-07-06at91sam9260/9263: add back up for the rst(reset controller).Sedji Gaouaou
On the boards at91sam9260ek, at91sam9263ek and afed9260, the rstc register was set to 0 after being set to 500 ms for the PHY reset. Do backup the old reset length and restore it after the MACB initialisation. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Stelian Pop <stelian@popies.net>
2009-05-13AFEB9260 network fixSergey Lapin
AFEB9260 uses PA10, PA11 for ETX2 and ETX3. Also, due to extarnal pull-up on IRQ line, Micrel PHY ID is 1 after reset sequence, not 0. Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2009-03-22at91sam9/at91cap: move nand drivers to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common macb initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common spi initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common serial initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-11-07AT91: Replace AT91_BASE_EMAC by the board specific values.Stelian Pop
AT91_BASE_EMAC is never used outside the board specific files, so replace its usage by the board specific AT91xxx_BASE_EMAC. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-07AT91: Replace (undefined) AT91_ID_US* by the board specific values.Stelian Pop
AT91_ID_US0 / AT91_ID_US1 / AT91_ID_US2 were used but never defined. Since they are never used outside the board specific files, they can be replaced by the board specific AT91xxx_ID_US0 / AT91xxx_ID_US1 / AT91xxx_ID_US2. Bug spotted by Jesus Alvarez <jalvarez@micromint.com>. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-04Custom AFEB9260 board supportSergey Lapin
This patch provides support for AFEB9260 board, a product of OpenSource hardware and software. Some commertial projects are made with this design. A board is basically AT91SAM9260-EK with some modifications and different peripherals and different parts used. Main purpose of this project is to gain experience in hardware design. More info: http://groups.google.com/group/arm9fpga-evolution-board (In Russian only, sorry). Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb Signed-off-by: Sergey Lapin <slapin@ossfans.org>
