path: root/board/advantech
2017-10-19x86: baytrail: fsp: Move Azalia update codes to boardBin Meng
Azalia configuration may be different across boards, hence it's not appropriate to do that in the SoC level. Instead, let's make the SoC update_fsp_azalia_configs() routine as a weak version, and do the actual work in the board codes. So far it seems only som-db5800-som-6867 board enables the Azalia. Move the original codes into som-db5800-som-6867.c. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-12imx: Include <input.h> header fileDiego Dorta
When building with W=1 errors like the one below is seen: board/freescale/mx6sabresd/mx6sabresd.c:546:5: warning: no previous prototype for ‘overwrite_console’ [-Wmissing-prototypes] int overwrite_console(void) Fix the build warnings by including <input.h>. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-01x86: kconfig: Let board select SPI flashBin Meng
Only a specific type of SPI flash exists on a board, having board Kconfig to select the SPI flash seems to make more sense. Other flash types are not necessary except coreboot, which implies all available flash drivers there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Select ARCH_EARLY_INIT_R in the platform KconfigBin Meng
This is architecture-dependent early initialization hence should be put in the platform Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Let board select BOARD_EARLY_INIT_FBin Meng
CONFIG_BOARD_EARLY_INIT_F literally indicates board-specific codes and should be not 'default y' for all x86 boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-12board: advantech: dms-ba16: apply the proper register setting to fix the ↵Yung-Ching LIN
voltage peak issue Apply the proper setting for the reserved bits in SetDes Test and System Mode Control register to avoid the voltage peak issue while we do the IEEE PHY comformance test Signed-off-by: Ken Lin <yungching0725@gmail.com> Acked-by: Akshay Bhat <akshay.bhat@timesys.com>
2017-04-12board: advantech: dms-ba16: fix AR8033 reset timing issueYung-Ching LIN
Add the delay (10ms) to ensure the clock is stable and to meet the clock-to-reset(1ms) requirement recommended in the AR8033 datasheet Signed-off-by: Ken Lin <yungching0725@gmail.com> Acked-by: Akshay Bhat <akshay.bhat@timesys.com>
2017-04-12board: advantech: dms-ba16: add the PMIC configuration supportYung-Ching LIN
Change the PMIC bulk configuration from auto mode to sync mode to avoid the voltage shutdown issue Signed-off-by: Ken Lin <yungching0725@gmail.com> Acked-by: Akshay Bhat <akshay.bhat@timesys.com>
2017-04-12board: advantech: dms-ba16: Add the configuration options for display ↵Yung-Ching LIN
initialization Add the configuration options for display initialization in case we need to do the display initialization in kernel to support different timing settings Signed-off-by: Ken Lin <yungching0725@gmail.com> Acked-by: Akshay Bhat <akshay.bhat@timesys.com>
2016-09-06arm: imx: Add support for Advantech DMS-BA16 boardAkshay Bhat
Add support for Advantech DMS-BA16 board. The board is based on Advantech BA16 module which has a i.MX6D processor. The board supports: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: u-boot@lists.denx.de Cc: sbabic@denx.de
2016-07-12x86: Add Advantech SOM-DB5800/SOM-6867 supportGeorge McCollister
Add support for Advantech SOM-DB5800 with the SOM-6867 installed. This is very similar to conga-qeval20-qa3-e3845 in that there is a reference carrier board (SOM-DB5800) with a Baytrail based SoM (SOM-6867) installed. Currently supported: - 2x UART (From ITE EC on SOM-6867) routed to COM3/4 connectors on SOM-DB5800. - 4x USB 2.0 (EHCI) - Video - SATA - Ethernet - PCIe - Realtek ALC892 HD Audio Pad configuration for HDA_RSTB, HDA_SYNC, HDA_CLK, HDA_SDO HDA_SDI0 is set in DT to enable HD Audio codec. Pin defaults for codec pin complexs are not changed. Not supported: - Winbond Super I/O (Must be disabled with jumpers on SOM-DB8500) - USB 3.0 (XHCI) - TPM Signed-off-by: George McCollister <george.mccollister@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
