Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
Update reference in many files detected by
scripts/documentation-file-ref-check
README.imximage => imx/mkimage/imximage.txt
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
imx8: cleanup, fix warnings
imx6ull: add VisionSOM SoM and EVK
mx7ulp: fix warning due network, cleanup
mx7dsabre: Fix dm probe pmic
imx6: fixed for vining2000
Travis: https://travis-ci.org/sbabic/u-boot-imx/builds/639512296
detail_board_ddr_info() is not used anywhere, so simply remove it.
This function is only used by Layerscape, not by i.MX.
This was detected by the following sparse warning:
board/advantech/imx8qm_rom7720_a1/imx8qm_rom7720_a1.c:110:6: warning: no previous
prototype for ‘detail_board_ddr_info’ [-Wmissing-prototypes]
Signed-off-by: Alifer Moraes <alifer.wsdm@gmail.com>
Reviewed-by: Oliver Graute <oliver.graute@kococonnector.com>
Move this function out of common.h and into a relevant header file.
A number of board function belong in init.h with the others. Move them.
Add i.MX8QM ROM 7720a1 board support
Boot log as below:
U-Boot 2019.10-rc3-00004-gd073e0242f (Sep 20 2019 - 08:24:13 +0200)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
Model: Advantech iMX8QM Qseven series
Board: ROM-7720-A1 4GB
Build: SCFW 65afe5f6
Boot: SD2
DRAM: 4 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... OK
In: serial@5a060000
Out: serial@5a060000
Err: serial@5a060000
Net: eth0: ethernet@5b040000Could not get PHY for FEC1: addr 1
, eth-1: ethernet@5b050000
Hit any key to stop autoboot: 0
Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: uboot-imx <uboot-imx@nxp.com>
Since there is now a new version of the FSP and it is incompatible with
the existing version, move the code into an fsp1 directory. This will
allow us to put FSP v2 code into an fsp2 directory.
Add a Kconfig which defines which version is in use.
Some of the code in this new fsp1/ directory is generic across both FSPv1
and FSPv2. Future patches will address this.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
Now that we have generic EFI payload support, drop EFI-specific test
logics in BayTrail Kconfig and codes, and all BayTrail boards too.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Azalia configuration may be different across boards, hence it's not
appropriate to do that in the SoC level. Instead, let's make the
SoC update_fsp_azalia_configs() routine as a weak version, and do
the actual work in the board codes.
So far it seems only som-db5800-som-6867 board enables the Azalia.
Move the original codes into som-db5800-som-6867.c.
When building with W=1 errors like the one below is seen:
board/freescale/mx6sabresd/mx6sabresd.c:546:5: warning:
no previous prototype for ‘overwrite_console’
[-Wmissing-prototypes] int overwrite_console(void)
Fix the build warnings by including <input.h>.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Only a specific type of SPI flash exists on a board, having board
Kconfig to select the SPI flash seems to make more sense. Other
flash types are not necessary except coreboot, which implies all
available flash drivers there.
This is architecture-dependent early initialization hence should
be put in the platform Kconfig.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
CONFIG_BOARD_EARLY_INIT_F literally indicates board-specific codes
and should be not 'default y' for all x86 boards.
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
At present CONFIG_CMD_SATA enables the 'sata' command which also brings
in SATA support. Some boards may wish to enable SATA without the command.
Add a separate CONFIG to permit this.
voltage peak issue
Apply the proper setting for the reserved bits in SetDes Test and System Mode Control register
to avoid the voltage peak issue while we do the IEEE PHY comformance test
Signed-off-by: Ken Lin <yungching0725@gmail.com>
Acked-by: Akshay Bhat <akshay.bhat@timesys.com>
Add the delay (10ms) to ensure the clock is stable and to meet the clock-to-reset(1ms) requirement recommended in the AR8033 datasheet
Change the PMIC bulk configuration from auto mode to sync mode to avoid the voltage shutdown issue
initialization
Add the configuration options for display initialization in case we need to
do the display initialization in kernel to support different timing settings
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
Add support for Advantech DMS-BA16 board. The board is based on Advantech
BA16 module which has a i.MX6D processor. The board supports:
- FEC Ethernet
- USB Ports
- SDHC and MMC boot
- SPI NOR
- LVDS and HDMI display
Basic information about the module:
- Module manufacturer: Advantech
- CPU: Freescale ARM Cortex-A9 i.MX6D
- SPECS:
Up to 2GB Onboard DDR3 Memory;
Up to 16GB Onboard eMMC NAND Flash
Supports OpenGL ES 2.0 and OpenVG 1.1
HDMI, 24-bit LVDS
1x UART, 2x I2C, 8x GPIO,
4x Host USB 2.0 port, 1x USB OTG port,
1x micro SD (SDHC),1x SDIO, 1x SATA II,
1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Cc: u-boot@lists.denx.de
Cc: sbabic@denx.de
Add support for Advantech SOM-DB5800 with the SOM-6867 installed.
This is very similar to conga-qeval20-qa3-e3845 in that there is a
reference carrier board (SOM-DB5800) with a Baytrail based SoM (SOM-6867)
installed.
Currently supported:
- 2x UART (From ITE EC on SOM-6867) routed to COM3/4 connectors on
SOM-DB5800.
- 4x USB 2.0 (EHCI)
- Video
- SATA
- Ethernet
- PCIe
- Realtek ALC892 HD Audio
Pad configuration for HDA_RSTB, HDA_SYNC, HDA_CLK, HDA_SDO
HDA_SDI0 is set in DT to enable HD Audio codec.
Pin defaults for codec pin complexs are not changed.
Not supported:
- Winbond Super I/O (Must be disabled with jumpers on SOM-DB8500)
- USB 3.0 (XHCI)
- TPM
Signed-off-by: George McCollister <george.mccollister@gmail.com>
