path: root/board/advantech/dms-ba16
2016-09-06arm: imx: Add support for Advantech DMS-BA16 boardAkshay Bhat
Add support for Advantech DMS-BA16 board. The board is based on Advantech BA16 module which has a i.MX6D processor. The board supports: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: u-boot@lists.denx.de Cc: sbabic@denx.de
