path: root/board/ads5121
2008-02-07ADS5121e: DDR2 init/timing update.Grzegorz Bernacki
Signed-off-by: John Rigby <jrigby@freescale.com> Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2008-01-13ADS5121: Fix typo in ads5121.c, adjust default environmentWolfgang Denk
2008-01-13ADS5121: MAX slew rate for PATA pinsJohn Rigby
2008-01-13ADS5121e: fix compile warningWolfgang Denk
2008-01-12ads5121: Added support for FDT.Grzegorz Bernacki
2007-11-15Revert "[MPC512x] Correct fixup relocation"Grant Likely
This reverts commit 8d17979d0359492a822a0a409d26e3a3549b4cd4. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-07[MPC512x] Correct fixup relocationRafal Jaworowski
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2007-08-12Cleanup output on ADS5121 boardWolfgang Denk
2007-08-02Coding style cleanup, update CHANGELOGWolfgang Denk
2007-07-27[ADS5121] Support for the ADS5121 boardRafal Jaworowski
The following MPC5121e subsystems are supported: - low-level CPU init - NOR Boot Flash (common CFI driver) - DDR SDRAM - FEC - I2C - Watchdog Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Jan Wrobel <wrr@semihalf.com>
