path: root/board/adder
2008-03-258xx : Add OF support to Adder875 board port - resubmitBryan O'Donoghue
Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie>
2006-03-12Add support for Adder boards with 16MB SDRAM;Wolfgang Denk
add support for second FEC on Adder87x board. Patch by Yuli Barcohen, 05 Jun 2005
2004-06-09* Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for Analogue&Micro Adder87x and the older AdderII board. * Patch by Ming-Len Wu, 09 Jun 2004: Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
