path: root/board/actux3
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-03-02actua1/actua2/actua3: Fix multiple unused variable warningsJean-Christophe PLAGNIOL-VILLARD
- actua1: actux1.c: In function 'checkboard': actux1.c:92: warning: unused variable 'revision' - actua2: actux2.c: In function 'checkboard': actux2.c:100: warning: unused variable 's' actux2.c:99: warning: unused variable 'revision' actux2.c: In function 'reset_phy': actux2.c:130: warning: unused variable 'i' - actua3: actux3.c: In function 'checkboard': actux3.c:114: warning: unused variable 'revision' Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-18add AcTux-3 board supportMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
