path: root/board/actux2
2013-06-21arm: make __rel_dyn_{start, end} compiler-generatedAlbert ARIBAUD
This change is only done where needed: some linker scripts may contain relocation symbols yet remain unchanged. __rel_dyn_start and __rel_dyn_end each requires its own output section; putting them in relocation sections changes their flags and breaks relocation. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: make __image_copy_{start, end} compiler-generatedAlbert ARIBAUD
This change is only done where needed: some linker scripts may contain __image_copy_{start,end} yet remain unchanged. Also, __image_copy_end needs its own section; putting it in relocation sections changes their flags and makes relocation break. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21remove all references to .dynsymAlbert ARIBAUD
Discard all .dynsym sections from linker scripts Remove all __dynsym_start definitions from linker scripts Remove all __dynsym_start references from the codebase Note: this touches include/asm-generic/sections.h, which is not ARM-specific, but actual uses of __dynsym_start are only in ARM, so this patch can safely go through the ARM repository. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-13ARM: Fix __bss_start and __bss_end in linker scriptsAlbert ARIBAUD
Commit 3ebd1cbc introduced compiler-generated __bss_start and __bss_end__ and commit c23561e7 rewrote all __bss_end__ as __bss_end. Their merge caused silent and harmless but potentially bug-inducing clashes between compiler- and linker- generated __bss_end symbols. Make __bss_end and __bss_start compiler-only, and create __bss_base and __bss_limit for linker-only use. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: relocate_code(): Use __image_copy_end for end of relocationBenoît Thébaudeau
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S. This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-12arm: make __bss_start and __bss_end__ compiler-generatedAlbert ARIBAUD
Turn __bss_start and __bss_end__ from linker-generated to compiler-generated symbols, causing relocations for these symbols to change type, from R_ARM_ABS32 to R_ARM_RELATIVE. This should have no functional impact, as it affects references to __bss_start and __bss_end__ only before relocation, and no such references are done. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-18actux[123]: Update linker script for ELDK 4.2Tom Rini
With ELDK4.2 libserial.o is too large to fit in the area before the environment. Swap in libinput instead which is a little smaller. Cc: Michael Schwingen <michael@schwingen.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-03-26IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST}Marek Vasut
These symbols are no longer defined in Linux-ARM's mach-types files. Replace these with CONFIG_MACH_TYPE instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bryan Hundven <bryanhundven@gmail.com> Cc: Michael Schwingen <rincewind@discworld.dascon.de>
2011-06-23update/fix AcTux2 boardMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-03-02actua1/actua2/actua3: Fix multiple unused variable warningsJean-Christophe PLAGNIOL-VILLARD
- actua1: actux1.c: In function 'checkboard': actux1.c:92: warning: unused variable 'revision' - actua2: actux2.c: In function 'checkboard': actux2.c:100: warning: unused variable 's' actux2.c:99: warning: unused variable 'revision' actux2.c: In function 'reset_phy': actux2.c:130: warning: unused variable 'i' - actua3: actux3.c: In function 'checkboard': actux3.c:114: warning: unused variable 'revision' Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-18add AcTux-2 board supportMichael Schwingen
