path: root/board/abilis
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-12ARC: rework setting of ARC CPU specific compiler optionsEugeniy Paltsev
It's a very rare if at all existing occasion when ARC CPU template is used as is w/o any changes - in the end it's a beauty and competitive advantage of ARC cores to be tailored for a particular use-case - and so it doesn't make a lot of sense to offer template-based "-mcpu" selection. Given for each and every platform we end-up adding quite a few more flags it's logical to move "-mcpu" selection to platform's definition as well which we exactly do here. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-27tb100 - add Abilis TB100 boardAlexey Brodkin
Development board for headless gateway platform from Abilis Systems. Initial commit with working UART and DW GMAC. For now with generic Ethernet PHY due to problems in Realtek PHY driver. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Ruppert <christian.ruppert@abilis.com> Cc: Pierrick Hascoet <pierrick.hascoet@abilis.com>
