path: root/board/a4m072
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-10-21a4m072: change 'display' command implementationIlya Yanok
This patch changes implementation of 'display' command for a4m072 that uses 7-segment LED display as customer requested: a) The "display" command shall _not_ turn on the decimal point. b) Exception: "display ." shall turn on (only) the decimal point. c) Hex digits (0-9, A-F, a-f) shall be displayed as usual. d) Letters U, P, Y, L, S, T, H shall be displayed as usual (lower case letters identical to upper case letters) e) 'I' (and 'i') shall be displayed like '1' f) 'O' (and 'o') shall be displayed like '0' g) all other Characters shall be displayed like ' ' (all segments off). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-18Rename TEXT_BASE: fix merge conflictsWolfgang Denk
Commit 14d0a02a "Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE" missed a few places, especially for boards that were added inbetween. Fix the remaining issues. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-12a4m072: support for SHOW_BOOT_PROGRESS feature using LED displayIlya Yanok
This patch adds support for displaying boot progress codes on a4m072 board using LED display. As we can display only one symbol at any time on the hardware (two symbols with blinking) we can't display progress codes directly and have to map them to 2-symbol codes. We use the following mapping on the a4m972 board: [1, 8] U [100, 108] -> 5 [-9, -1] U [-101, -100] U [-113, -103] -> -5 [9, 14] U [120, 123] U [125, 129] -> 8 [-13, -10] U [-122, -120] U [-127, -124] U {-129} -> -8 {15} -> 9 [-32, -30] -> -A [-40, -35] U [-51, -42] U [-58, -53] U [-83, -80] U {-64, -130, -140, -150} -> -B Other progress code are ignored. One symbol codes are displayed steady while two-symbol codes are displayed using blinking. Boot progress codes are displayed with decimal got unset (as opposed to 'display' command output). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-12a4m072: led display supportIlya Yanok
This patch adds support for LED display on a4m072 board. Hardware is capable of displaying only one symbol at any time. We support displaying two symbols in software (via blinking). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-12A4M072: Added support for the board.Sergei Poselenov
This patch provides support for the A4M072 board with the following features: UART NOR flash FEC Ethernet External SRAM I2C EEPROM CompactFlash cards on IDE/ATA port USB Host PCI initialization The 7-segment LED indicator is not yet supported. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
