path: root/board/Seagate
2013-01-09kirkwood: make MPP arrays static constAlbert ARIBAUD
This saves stack and code memory for local copy, and consumes initialized data memory. For 22 of the 29 kirkwood-based boards, this results in a global saving of about 30 bytes. For 7 of them, it results in an increase of 6 to 14 bytes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-07-07kirkwood: fix calls to kirkwood_mpp_confValentin Longchamp
With the new second save argument introduced by the previous patch, all the calls to the function had to be fixed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-03-18bootstage: Convert net progress numbers to enumsSimon Glass
This changes over the network-related progress numbers to use enums from bootstage.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-03ARM: DockStar: fix compilationAnatolij Gustschin
Fix build problem: mvgbe.c: In function 'mvgbe_initialize': mvgbe.c:735: warning: implicit declaration of function 'get_random_hex' dockstar.c: In function 'board_early_init_f': dockstar.c:43: warning: implicit declaration of function 'kw_config_gpio' dockstar.c: In function 'board_init': dockstar.c:113: warning: implicit declaration of function 'kw_sdram_bar' dockstar.c: In function 'set_leds': dockstar.c:161: warning: implicit declaration of function 'readl' dockstar.c:161: error: dereferencing pointer to incomplete type dockstar.c:162: warning: implicit declaration of function 'writel' dockstar.c:162: error: dereferencing pointer to incomplete type dockstar.c:163: error: dereferencing pointer to incomplete type dockstar.c:164: error: dereferencing pointer to incomplete type make[1]: *** [dockstar.o] Error 1 make: *** [board/Seagate/dockstar/libdockstar.o] Error 2 Reported-by: Roland Kletzing <devzero@web.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2010-11-26Seagate FreeAgent DockStar supportEric Cooper
start with sheevaplug configuration add modifications by Alexander Holler <holler@ahsoftware.de> change RAM definitions to one bank (128 MB) change ident string and prompt define MTD partitions and default environment variables add support for LEDs Signed-off-by: Eric Cooper <ecc@cmu.edu>
