path: root/board/RPXlite_dw
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-04-02replace last __bss_end__ occurrences with __bss_endAlbert ARIBAUD
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a, which changed all occurrences of __bss__end__ into __bss_end, left behind some untouched __bss_end__ occurrences in all 33 u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and in board/mousse/u-boot.lds.rom. These are replaced here. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2005-01-10Coding Style cleanupwdenk
2005-01-09* Patch by Sam Song, 11 October 2004:wdenk
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board - Adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz * Patch by Sam Song, 10 Oct 2004: Fix a parameter error in run_command() in main.c
2004-06-09Patch by Sam Song, 09 Jun 2004:wdenk
- Add support for RPXlite_DW board - Update FLASH driver for 4*AM29DL323DB90VI - Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
