2010-10-18 | Makefile: move all Power Architecture boards into boards.cfg | Wolfgang Denk | |
Clean up Makefile, and drop a lot of the config.mk files on the way. We now also automatically pick all boards that are listed in boards.cfg (and with all configurations), so we can drop the redundant entries from MAKEALL to avoid building these twice. Signed-off-by: Wolfgang Denk <wd@denx.de> | |||
2010-10-18 | Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE | Wolfgang Denk | |
The change is currently needed to be able to remove the board configuration scripting from the top level Makefile and replace it by a simple, table driven script. Moving this configuration setting into the "CONFIG_*" name space is also desirable because it is needed if we ever should move forward to a Kconfig driven configuration system. Signed-off-by: Wolfgang Denk <wd@denx.de> | |||
2002-11-03 | Initial revision | wdenk | |
