path: root/board/MigoR
2008-07-08sh: Fix SH-boards compile errorNobuhiro Iwamatsu
By Cleanup out-or-tree building for some boards (.depend) (commit:c8a3b109f07f02342d097b30908965f7261d9f15) because filse ware changed, some SH-boards have compile error. I revised this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-02Cleanup: fix out-of-tree building for some boardsWolfgang Denk
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-03-28sh: Add support Renesas Solutions Migo-R boardgoda.yusuke
Migo-R is a board based on SH7722 and has may devices. In this patch, supported SCIF, NOR flash and Ethernet. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
