path: root/board/Marvell
2019-04-26arm: kirkwood: openrd: Mark openrd boards as maintained againStefan Roese
With the latest size increase of the openrd boards, they all compile clean again. Let's mark them as maintained again and add the Travis job. Please note that I can only compile-test these targets as I don't have access to one of those boards. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Albert ARIBAUD <albert-u-boot@aribaud.net> Cc: Vagrant Cascadian <vagrant@debian.org> Cc: Chris Packham <judge.packham@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2019-04-26ARM: kirkwood: add db-88f6281-bp boardChris Packham
This is Marvell's Kirkwood development board. It has the following features - 512M DDR2 - 2 PCI connectors - 1 x1 PCI-e interface - 1 Gigabit Ethernet Port - 2 SATA Ports - USB 2.0 Interface - SDIO - 128M NAND Flash - 16M SPI Flash It can be strapped to boot from SPI or NAND so there are two defconfigs (one per boot media). Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-12Merge git://git.denx.de/u-boot-marvellTom Rini
- Misc dts files sync'ed with Linux version (Chris) - Orion watchdog fix (Chris) - kwbimage changed to also support Marvell bin_hdr binary (Chris) - Add DM support to enable CONFIG_BLK for sata_mv (Stefan) - Enable BLK on multiple platforms (Stefan) - Misc minor fixes to AXP theadorable board (Stefan) - Correct logic for DM_SCSI + unconverted drivers check (stefan) - Misc changes to kirkwood to enable DM_USB here (Chris) - Change ahci_mvebu to enable usage on A38x (Baruch) - Update the kirkwood entry in git-mailrc (Baruch) - Misc minor improvements (turris, documentation) (Baruch) - Enhance sata_mv to support Kirkwood as well (Michael) - Add wdt command (Michael) - Add Marvell integrated CPUs (MSYS) support with DB-XC3-24G4XG board support (Chris)
2019-04-12arm: mvebu: Add DB-XC3-24G4XG boardChris Packham
The DB-XC3-24G4XG is a switch development board from Marvell. It can either use and external CPU card such as the db-88f6820-amc or the internal CPU that is integrated into the switch. Add support for running U-Boot on the internal CPU and enable the USB, SPI and NAND peripherals. For now this needs the bin_hdr from the Marvell U-Boot for this board. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-05arm64: mvebu: Add basic support for uDPU boardVladimir Vid
This adds initial support for micro-DPU (uDPU) board which is based on Armada-3720 SoC. micro-DPU is the single-port FTTdp "distribution point unit" made by Methode Electronics which offers complete modularity with replaceable SFP modules both for uplink and downlink (G.hn over twisted-pair, G.hn over coax, 1G and 2.5G Ethernet over Cat-5e cable). On-board features: - 512 MiB DDR3 - 2 x 2.5G SFP via HSGMII SERDES interface to the A3720 SoC - USB 2.0 Type-C connector - 4GB eMMC - ETSI TS 101548 reverse powering via twisted pair (RJ45) or coax (F Type) Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Luis Torres <luis.torres@methode.com> Cc: Scott Roberts <scott.roberts@telus.com> Cc: Paul Arola <paul.arola@telus.com> Signed-off-by: Vladimir Vid <vladimir.vid@sartura.hr> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-01-21board: mvebu: drop unused ETH_PHY macro definitionsBaruch Siach
These macros are not used anywhere in the boards code. Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Dennis Gilmore <dgilmore@redhat.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09.02Chris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-18.09 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. Specifically this syncs with commit 99d772547314 ("Bump mv_ddr to release armada-18.09.2"). The complete log of changes is best obtained from the mv-ddr-marvell.git repository but some relevant highlights are: ddr3: add missing txsdll parameter ddr3: fix tfaw timimg parameter ddr3: fix trrd timimg parameter merge ddr3 topology header file with mv_ddr_topology one mv_ddr: a38x: fix zero memory size scrubbing issue The upstream code is incorporated omitting the portions not relevant to Armada-38x and DDR3. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT -UCONFIG_A3700 -UA3900 -UA80X0 \ -UA70X0 Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-06mvebu: select boot device at SoC levelBaruch Siach
Move the gdsys Controlcenter DC specific build time kwbimage.cfg generation code into the mach-mvebu/ directory to be shared by all 32bit mvebu platforms. Remove board specific kwbimage.cfg files, and use the generated one instead. These files are all identical, with two exceptions. Clearfog and Helios4 use the sdio boot device, whereas all others use spi. Update the defconfigs for the exceptional boards to generate the same kwbimage.cfg as before. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-07-31openrd: Mark as OrphanedTom Rini
After talking with Albert, mark these boards as orphaned as he no longer has one. Cc: Albert ARIBAUD <albert-u-boot@aribaud.net> Cc: Vagrant Cascadian <vagrant@debian.org> Cc: Chris Packham <judge.packham@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-14ARM: mvebu: a38x: restore support for setting timingChris Packham
This restores support for configuring the timing mode based on the ddr_topology. This was originally implemented in commit 90bcc3d38d2b ("driver/ddr: Add support for setting timing in hws_topology_map") but was removed as part of the upstream sync. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: sync ddr training code with upstreamChris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-17.10 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. The upstream code is incorporated omitting the ddr4 and apn806 and folding the nested a38x directory up one level. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT INTER_REGS_BASE is updated to be defined as SOC_REGS_PHY_BASE. Some now empty files are removed and the ternary license is replaced with a SPDX GPL-2.0+ identifier. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-03-30arm64: a37xx: remove old pinctrl implementationKen Ma
Since the new pinctrl/gpio driver is used, so this patch removes the old board specific pin control settings. Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Ken Ma <make@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-30arm: mvebu: correct comments around cas_wl/cas_lChris Packham
The order of members in struct hws_topology_map is cas_wl, cas_l. The comments in the original db-88f6820-gp.c had this wrong and have been copied to other Armada-385 based boards. Practically this hasn't made a difference since all these boards set both cas_wl and cas_l to 0 (autodetect) but if there were ever a board that did need to set these explicitly they would run into unexpected issued. Update the comments to reflect the correct order of structure members. Reported-by: Tobi Wulff <tobi.wulff@alliedtelesis.co.nz> Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-16mvebu: usb: xhci: a38x supportJon Nettleton
This makes the initial changes need to support the a38x series of SOCs. It adds the device-tree identifier as well as changing the board_support function to take the IO address designated by device-tree. Signed-off-by: Jon Nettleton <jon@solid-run.com> [baruch: use fdt_addr_t; update 37xx and 8K implementations] Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-21ARM: mvebu: set correct mem_size for db-88f6820-amcChris Packham
The db-88f6820-amc has four chips with 2Gb density giving a total of 1GB DRAM. Update the board_topology_map to reflect the correct configuration. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-12driver/ddr: Add support for setting timing in hws_topology_mapMarek Behún
The DDR3 training code for Marvell A38X currently computes 1t timing when given board topology map of the Turris Omnia, but Omnia needs 2t. This patch adds support for enforcing the 2t timing in struct hws_topology_map, through a new enum hws_timing, which can assume following values: HWS_TIM_DEFAULT - default behaviour, compute whether to enable 2t from the number of CSs HWS_TIM_1T - enforce 1t HWS_TIM_2T - enforce 2t This patch also sets all the board topology maps (db-88f6820-amc, db-88f6820-gp, controlcenterdc and clearfog) to have timing set to HWS_TIM_DEFAULT. Signed-off-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-23arm64: a37xx: Disable DB configurations on ESPRESSOBin boardKonstantin Porotchkin
Bypass XHCI and AHCi board configuration flow on ESPRESSOBin community board. The community board does not have i2c expander and USB VBUS is always on, so the scan for AHCi and USB devices can be faster without unneded configurations. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23mvebu: a37xx: Add init for ESPRESSBin Topaz switchKonstantin Porotchkin
Implement the board-specific network init function for ESPRESSOBin community board, setting the on-board Topaz switch port to forward mode and allow network connection through any of the available Etherenet ports. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23arm64: a37xx: Handle pin controls in early board initKonstantin Porotchkin
Fix the default pin control values in a board-specific function on early board init stage. This fix allows the NETA driver to work in RGMII mode until the full-featured pin control driver gets introduced. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23arm64: mvebu: Rename the db-88f3720 to armada-37xx platformKonstantin Porotchkin
Modify the file names and deifinitions relater to Marvell db-77f3720 board support. Convert these names to more generic armada-37xx platform for future addition of more boards based on the same SoC family. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-27Update Maintainer and Author's email addressAjay Bhargav
I am not longer using my old email address "ajay.bhargav@einfochips.com". For U-Boot development email address is now updated to contact@8051projects.net Signed-off-by: Ajay Bhargav <contact@8051projects.net>
2016-12-05arm64: mvebu: Add support for the DB-88F8040 Armada 8k devel boardStefan Roese
This patch adds the necessary files to support the Marvell Armada 8k devel board. Most board specfic files are shared with the Armada 7k boards under the name "armada-8k*". So only minimal changes are necessary to add this basic board support (except the DT files of course). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-12-05arm64: mvebu: armada-8k: Only configure xHCI power on DB-88F7040 boardStefan Roese
This patch uses of_machine_is_compatible() to detect the board at runtime and only configured the I2C IO expander for the xHCI power / reset on the DB-88F7040 board. As this code will be used by other Armada-7k/8k ports, its necessary to use this runtime detection here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-12-05arm64: mvebu: Rename db-88f7040 files to armada-8kStefan Roese
This moves some of the Armada DB-88F7040 board specific files to a more generic name: armada-8k. This is in preparation for the Armada-8k support which will be added soon. And since both platforms share most devices, lets also share most source files to not duplicate the code here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-09-27arm64: mvebu: Add Armada 7K db-88f7040 development board supportStefan Roese
This patch adds basic support for the Marvell Armada 7K DB-88F7040 development board. Supported are the following interfaces: - UART - SPI (incl. SPI NOR) - I2C - USB - SATA / AHCI Support for other interfaces will follow. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-09-27arm64: mvebu: Add Armada 3700 db-88f3720 development board supportStefan Roese
This patch adds basic support for the Marvell Armada 3700 DB-88F3720 development board. Supported are the following interfaces: - UART - SPI (incl. SPI NOR) - I2C - Ethernet Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com>
2016-09-24arm: mvebu: add DB-88F6820-AMC boardChris Packham
This board is a plug in card for Marvell's switch system development kits. Form-factor aside it is similar to the DB-88F6820-GP with the following differences. - TCLK is 200MHz - SPI1 is used - No SATA - No MMC - NAND flash Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-05-27MARVELL: Delete now-superfluous board/Marvell/{common, include} dirs.Robert P. J. Day
With dropping support for some boards and the deletion of some source files, it appears that both of these directories are now superfluous. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-04arm: mvebu: Add basic support for Armada 375 eval board db-88f6720Stefan Roese
This patch adds basic support for the Marvell A375 eval board. Tested are the following interfaces: - I2C - SPI - SPI NOR - Ethernet (mvpp2), port 0 & 1 Currently the A375 SerDes and DDR3 init code is not intergrated. So the SPL U-Boot is not fully functional. Right now, this A375 mainline U-Boot can only be used by chainloading it via the original Marvell U-Boot. This can be done via this command: => tftpboot 00800000 a375/u-boot-dtb.bin;go 00800000 Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-03-24arm: mvebu: db-88f6820: Drop obsolete binary.0 placeholderAndreas Färber
It has been superseded in kwbimage.cfg in favor of an SPL in commit 9e30b31d20f0b793465d07f056b3d9885f578c0d (arm: mvebu: db-88f6820: Add SPL support with DDR init code). Found via code review. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-14arm: mvebu: Consolidate board Kconfig options into one fileStefan Roese
Merging all the board specific Kconfig options into the main Kconfig file for mach-mvebu makes things easier to maintain. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14net: mvneta: Convert to driver modelStefan Roese
Update this driver to support driver model. As all MVEBU boards using this driver are converted with this patch, the non-driver-model code can be removed completely. This is also the reason why this patch is quite big and includes a) the driver change and b) the platform change. As its not git-bisect save otherwise. With this conversion, some parameters are now extracted from the DT instread of using the config header defines. The supported properties right now are: PHY-mode ("phy-mode") and PHY-address ("reg"). The base addresses for the ethernet controllers can be removed from the header files as well. Please note that this patch also removes the E1000 network driver from some MVEBU config headers. This is necessary, as with DM_ETH configured and the e1000 driver enabled, the PCI driver also needs to support DM. But the MVEBU PCI(e) driver still needs to get ported to DM. When this is done, the E1000 driver can be enabled again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2015-11-17arm: mvebu: a38x: serdes specification cleanupKevin Smith
Instead of allocating space in the driver for the serdes specification table, just allow the board file to set a pointer to it. Also, allow the board to only specify the lanes that are used instead of including unused lanes. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: mvebu: a38x: Remove unsupported topologiesKevin Smith
A lot of extra configuration information was left over in the Marvell serdes and DDR3 initialization code for boards that U-boot does not support. Remove this extra config information, and the concept of fixing up board topologies with information loaded from an EEPROM. If this needs to be done, it should be handled in the board file, not in core code. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-10-20arm: mvebu: Move Armada XP/38x Kconfig to mach specific Kconfig fileStefan Roese
Introduce a mach-mvebu/Kconfig for all Armada based SoC's. Signed-off-by: Stefan Roese <sr@denx.de>
2015-09-11arm: Remove rd6281a boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove openrd boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove mv88f6281gtw_ge boardSimon Glass
2015-08-17arm: mvebu: db-88f6820-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-88f6820-gp A38x eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-08-17arm: mvebu: db-mv784mp-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-mv784mp-gp AXP eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: Enable NAND controller on MVEBU SoC'sStefan Roese
This patch enables the NAND controller on the Armada XP/38x and provides a new function that returns the NAND controller input clock. This function will be used by the MVEBU NAND driver. As part of this patch, the multiple BIT macro definitions are moved to a common place in soc.h. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter Morrow <peter@senient.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-07-23arm: mvebu: db-88f6820: Add SPL support with DDR init codeStefan Roese
This patch adds SPL support for the Marvell DB-88F6820-GP board. With this change, the bin_hdr from the original Marvell U-boot is not needed any more on this board. The sources from bin_hdr (SERDES/PHY and DDR setup) are now integrated in mainline U-Boot. And this patch enables them for this board. Signed-off-by: Stefan Roese <sr@denx.de>
2015-07-10arm: mvebu: db-88f6820-gp: Add MAINTAINERS fileStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2015-05-05arm: mvebu: Add Armada A38x DB-88F6820-GP board supportStefan Roese
This patch adds support for the Marvell DB-88F6820-GP Armada A38x evaluation board. Supported peripherals are: - UART - Ethernet (mvneta) - I2C - SPI (including SPI NOR flash) Please note that this board support right now only supports the main U-Boot. Without the bin_hdr integration (DDR training etc). This will be added in a few days / weeks to complete this board port. But till then this U-Boot version can be run on the target via the original Marvell U-Boot via this command: tftpboot 4000000 db-88f6820-gp/u-boot.bin;go 4000000 Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
