path: root/board/Marvell
2018-05-14ARM: mvebu: a38x: restore support for setting timingChris Packham
This restores support for configuring the timing mode based on the ddr_topology. This was originally implemented in commit 90bcc3d38d2b ("driver/ddr: Add support for setting timing in hws_topology_map") but was removed as part of the upstream sync. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: sync ddr training code with upstreamChris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-17.10 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. The upstream code is incorporated omitting the ddr4 and apn806 and folding the nested a38x directory up one level. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT INTER_REGS_BASE is updated to be defined as SOC_REGS_PHY_BASE. Some now empty files are removed and the ternary license is replaced with a SPDX GPL-2.0+ identifier. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-03-30arm64: a37xx: remove old pinctrl implementationKen Ma
Since the new pinctrl/gpio driver is used, so this patch removes the old board specific pin control settings. Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Ken Ma <make@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-30arm: mvebu: correct comments around cas_wl/cas_lChris Packham
The order of members in struct hws_topology_map is cas_wl, cas_l. The comments in the original db-88f6820-gp.c had this wrong and have been copied to other Armada-385 based boards. Practically this hasn't made a difference since all these boards set both cas_wl and cas_l to 0 (autodetect) but if there were ever a board that did need to set these explicitly they would run into unexpected issued. Update the comments to reflect the correct order of structure members. Reported-by: Tobi Wulff <tobi.wulff@alliedtelesis.co.nz> Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-16mvebu: usb: xhci: a38x supportJon Nettleton
This makes the initial changes need to support the a38x series of SOCs. It adds the device-tree identifier as well as changing the board_support function to take the IO address designated by device-tree. Signed-off-by: Jon Nettleton <jon@solid-run.com> [baruch: use fdt_addr_t; update 37xx and 8K implementations] Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-21ARM: mvebu: set correct mem_size for db-88f6820-amcChris Packham
The db-88f6820-amc has four chips with 2Gb density giving a total of 1GB DRAM. Update the board_topology_map to reflect the correct configuration. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-12driver/ddr: Add support for setting timing in hws_topology_mapMarek Behún
The DDR3 training code for Marvell A38X currently computes 1t timing when given board topology map of the Turris Omnia, but Omnia needs 2t. This patch adds support for enforcing the 2t timing in struct hws_topology_map, through a new enum hws_timing, which can assume following values: HWS_TIM_DEFAULT - default behaviour, compute whether to enable 2t from the number of CSs HWS_TIM_1T - enforce 1t HWS_TIM_2T - enforce 2t This patch also sets all the board topology maps (db-88f6820-amc, db-88f6820-gp, controlcenterdc and clearfog) to have timing set to HWS_TIM_DEFAULT. Signed-off-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-23arm64: a37xx: Disable DB configurations on ESPRESSOBin boardKonstantin Porotchkin
Bypass XHCI and AHCi board configuration flow on ESPRESSOBin community board. The community board does not have i2c expander and USB VBUS is always on, so the scan for AHCi and USB devices can be faster without unneded configurations. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23mvebu: a37xx: Add init for ESPRESSBin Topaz switchKonstantin Porotchkin
Implement the board-specific network init function for ESPRESSOBin community board, setting the on-board Topaz switch port to forward mode and allow network connection through any of the available Etherenet ports. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23arm64: a37xx: Handle pin controls in early board initKonstantin Porotchkin
Fix the default pin control values in a board-specific function on early board init stage. This fix allows the NETA driver to work in RGMII mode until the full-featured pin control driver gets introduced. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-23arm64: mvebu: Rename the db-88f3720 to armada-37xx platformKonstantin Porotchkin
Modify the file names and deifinitions relater to Marvell db-77f3720 board support. Convert these names to more generic armada-37xx platform for future addition of more boards based on the same SoC family. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-27Update Maintainer and Author's email addressAjay Bhargav
I am not longer using my old email address "ajay.bhargav@einfochips.com". For U-Boot development email address is now updated to contact@8051projects.net Signed-off-by: Ajay Bhargav <contact@8051projects.net>
2016-12-05arm64: mvebu: Add support for the DB-88F8040 Armada 8k devel boardStefan Roese
This patch adds the necessary files to support the Marvell Armada 8k devel board. Most board specfic files are shared with the Armada 7k boards under the name "armada-8k*". So only minimal changes are necessary to add this basic board support (except the DT files of course). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-12-05arm64: mvebu: armada-8k: Only configure xHCI power on DB-88F7040 boardStefan Roese
This patch uses of_machine_is_compatible() to detect the board at runtime and only configured the I2C IO expander for the xHCI power / reset on the DB-88F7040 board. As this code will be used by other Armada-7k/8k ports, its necessary to use this runtime detection here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-12-05arm64: mvebu: Rename db-88f7040 files to armada-8kStefan Roese
This moves some of the Armada DB-88F7040 board specific files to a more generic name: armada-8k. This is in preparation for the Armada-8k support which will be added soon. And since both platforms share most devices, lets also share most source files to not duplicate the code here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-09-27arm64: mvebu: Add Armada 7K db-88f7040 development board supportStefan Roese
This patch adds basic support for the Marvell Armada 7K DB-88F7040 development board. Supported are the following interfaces: - UART - SPI (incl. SPI NOR) - I2C - USB - SATA / AHCI Support for other interfaces will follow. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-09-27arm64: mvebu: Add Armada 3700 db-88f3720 development board supportStefan Roese
This patch adds basic support for the Marvell Armada 3700 DB-88F3720 development board. Supported are the following interfaces: - UART - SPI (incl. SPI NOR) - I2C - Ethernet Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Wilson Ding <dingwei@marvell.com> Cc: Victor Gu <xigu@marvell.com> Cc: Hua Jing <jinghua@marvell.com> Cc: Terry Zhou <bjzhou@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Cc: Haim Boot <hayim@marvell.com>
2016-09-24arm: mvebu: add DB-88F6820-AMC boardChris Packham
This board is a plug in card for Marvell's switch system development kits. Form-factor aside it is similar to the DB-88F6820-GP with the following differences. - TCLK is 200MHz - SPI1 is used - No SATA - No MMC - NAND flash Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-05-27MARVELL: Delete now-superfluous board/Marvell/{common, include} dirs.Robert P. J. Day
With dropping support for some boards and the deletion of some source files, it appears that both of these directories are now superfluous. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-04arm: mvebu: Add basic support for Armada 375 eval board db-88f6720Stefan Roese
This patch adds basic support for the Marvell A375 eval board. Tested are the following interfaces: - I2C - SPI - SPI NOR - Ethernet (mvpp2), port 0 & 1 Currently the A375 SerDes and DDR3 init code is not intergrated. So the SPL U-Boot is not fully functional. Right now, this A375 mainline U-Boot can only be used by chainloading it via the original Marvell U-Boot. This can be done via this command: => tftpboot 00800000 a375/u-boot-dtb.bin;go 00800000 Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-03-24arm: mvebu: db-88f6820: Drop obsolete binary.0 placeholderAndreas Färber
It has been superseded in kwbimage.cfg in favor of an SPL in commit 9e30b31d20f0b793465d07f056b3d9885f578c0d (arm: mvebu: db-88f6820: Add SPL support with DDR init code). Found via code review. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-14arm: mvebu: Consolidate board Kconfig options into one fileStefan Roese
Merging all the board specific Kconfig options into the main Kconfig file for mach-mvebu makes things easier to maintain. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14net: mvneta: Convert to driver modelStefan Roese
Update this driver to support driver model. As all MVEBU boards using this driver are converted with this patch, the non-driver-model code can be removed completely. This is also the reason why this patch is quite big and includes a) the driver change and b) the platform change. As its not git-bisect save otherwise. With this conversion, some parameters are now extracted from the DT instread of using the config header defines. The supported properties right now are: PHY-mode ("phy-mode") and PHY-address ("reg"). The base addresses for the ethernet controllers can be removed from the header files as well. Please note that this patch also removes the E1000 network driver from some MVEBU config headers. This is necessary, as with DM_ETH configured and the e1000 driver enabled, the PCI driver also needs to support DM. But the MVEBU PCI(e) driver still needs to get ported to DM. When this is done, the E1000 driver can be enabled again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2015-11-17arm: mvebu: a38x: serdes specification cleanupKevin Smith
Instead of allocating space in the driver for the serdes specification table, just allow the board file to set a pointer to it. Also, allow the board to only specify the lanes that are used instead of including unused lanes. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: mvebu: a38x: Remove unsupported topologiesKevin Smith
A lot of extra configuration information was left over in the Marvell serdes and DDR3 initialization code for boards that U-boot does not support. Remove this extra config information, and the concept of fixing up board topologies with information loaded from an EEPROM. If this needs to be done, it should be handled in the board file, not in core code. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-10-20arm: mvebu: Move Armada XP/38x Kconfig to mach specific Kconfig fileStefan Roese
Introduce a mach-mvebu/Kconfig for all Armada based SoC's. Signed-off-by: Stefan Roese <sr@denx.de>
2015-09-11arm: Remove rd6281a boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove openrd boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove mv88f6281gtw_ge boardSimon Glass
2015-08-17arm: mvebu: db-88f6820-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-88f6820-gp A38x eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-08-17arm: mvebu: db-mv784mp-gp: Enable PCI supportStefan Roese
This patch enabled the MVEBU PCIe support on the db-mv784mp-gp AXP eval board. It also enabled the Intel E1000 driver support and adds the initialization of PCIe network controllers to the board code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Anton Schubert <anton.schubert@gmx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-08-17arm: mvebu: Enable NAND controller on MVEBU SoC'sStefan Roese
This patch enables the NAND controller on the Armada XP/38x and provides a new function that returns the NAND controller input clock. This function will be used by the MVEBU NAND driver. As part of this patch, the multiple BIT macro definitions are moved to a common place in soc.h. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter Morrow <peter@senient.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-07-23arm: mvebu: db-88f6820: Add SPL support with DDR init codeStefan Roese
This patch adds SPL support for the Marvell DB-88F6820-GP board. With this change, the bin_hdr from the original Marvell U-boot is not needed any more on this board. The sources from bin_hdr (SERDES/PHY and DDR setup) are now integrated in mainline U-Boot. And this patch enables them for this board. Signed-off-by: Stefan Roese <sr@denx.de>
2015-07-10arm: mvebu: db-88f6820-gp: Add MAINTAINERS fileStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2015-05-05arm: mvebu: Add Armada A38x DB-88F6820-GP board supportStefan Roese
This patch adds support for the Marvell DB-88F6820-GP Armada A38x evaluation board. Supported peripherals are: - UART - Ethernet (mvneta) - I2C - SPI (including SPI NOR flash) Please note that this board support right now only supports the main U-Boot. Without the bin_hdr integration (DDR training etc). This will be added in a few days / weeks to complete this board port. But till then this U-Boot version can be run on the target via the original Marvell U-Boot via this command: tftpboot 4000000 db-88f6820-gp/u-boot.bin;go 4000000 Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-05-05arm: mvebu: Change network init code to allow a more flexible setupStefan Roese
With the introduction of the Armada 38x support, its necessary to change the mvneta ethernet driver init call from always 4 times to a configurable value. Lets make this init call more flexible by moving the actually used devices to the config header. Additionally this patch takes care of the slightly different base addresses for the ethernet controllers on A38x. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-05arm: armada-xp: Move SoC headers to mach-mvebu/include/machStefan Roese
Move arch/arm/include/asm/arch-armada-xp/* -> arch/arm/mach-mvebu/include/mach/* Additionally the SYS_SOC is renamed from "armada-xp" to "mvebu". With this change all these files can better be shared with other, newer Mavell MVEBU SoC's. Like the upcoming Armada 38x support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-02-24ARM: remove dkb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Lei Wen <leiwen@marvell.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-06arm: db-mv784mp-gp: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the db-mv784mp-gp eval board. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-06arm: mvebu: Placeholder bin_hdr file can now be removedStefan Roese
With this patchset the Marvell bin_hdr (DDR training) code is intergrated into mainline U-Boot. We can remove the placeholder file again, which was only introduced to make U-Boot compile and link again. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2014-11-13kconfig: arm: select CPU_V7 for some new boardsMasahiro Yamada
This commit adds "select CPU_V7" for some new boards that were not covered by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). Redundant "SYS_CPU" defines and "string" directives should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27arm: db-mv784mp-gp/maxbcm Add placeholder bin_hdr file so that linking worksStefan Roese
This file should contain the bin_hdr generated by the original Marvell U-Boot implementation. As this is currently not included in this U-Boot version, we have added this placeholder, so that the U-Boot image can be generated without errors. If you have a known to be working bin_hdr for your board, then you just need to replace this text file here with the binary header and recompile U-Boot. In a few weeks, mainline U-Boot will get support to generate the bin_hdr with the DDR training code itself. By implementing this code as SPL U-Boot. Then this file will not be needed any more and will get removed. Signed-off-by: Stefan Roese <sr@denx.de>
2014-10-27PowerPC: drop some 74xx_7xx boards and related codeWolfgang Denk
The file board/Marvell/include/mv_gen_reg.h is incompatible with the GPL (see for example the "MARVELL RESERVES THE RIGHT AT ITS SOLE DISCRETION TO REQUEST THAT THIS CODE BE IMMEDIATELY RETURNED TO MARVELL" clause). As this cannot be fixed, we remove the file and all code that depends on it. Fortunately this only affects some very old boards that have long reached EOL: CPCI750 DB64360 DB64460 p3m750 p3m7448 Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: Roger Meier <r.meier@siemens.com>
