path: root/board/Marvell
2009-09-10Kirkwood: Sheevaplug: Add kwimage configuration filePrafulla Wadaskar
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-23Marvell RD6281A Board supportPrafulla Wadaskar
This is Marvell's 88F6281_A0 based reference design board This patch is tested for- 1. Boot from DRAM/NAND flash/NFS 2. File transfer using tftp and loadb 3. NAND flash read/write/erase Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-18Marvell MV88F6281GTW_GE Board supportPrafulla Wadaskar
This is Marvell's 88F6281_A0 based custom board developed for wireless access point product This patch is tested for- 1. Boot from DRAM/SPI flash/NFS 2. File transfer using tftp and loadb 3. SPI flash read/write/erase 4. Booting Linux kernel and RFS from SPI flash 5. Boot from USB supported Reviewed-by: Ronen Shitrit <rshitrit@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-18Marvell Sheevaplug Board supportPrafulla Wadaskar
Reference: http://plugcomputer.org/ http://openplug.org/plugwiki/index.php/Das_U-boot_plug_support This patch is tested for- 1. Boot from DRAM/NAND flash 2. File transfer using tftp 3. NAND flash read/write/erase 4. Linux kernel and RFS Boot from NAND 5. Enabled USB PHY init for kernel need 6. Boot from USB supported Note: to boot Kirkwood kernel with USB support, you should add "usb start" in the boot sequence Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-09asm-generic: Consolidate errno.h to asm-generic/errno.hMichal Simek
This patch use blackfin errno.h implementation which correspond Linux kernel one. MIPS implemetation is different that's why I keep it. I removed ppc_error_no.h from Marvell boards which was the same too. I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-06-12Marvell: i2c cleanupPeter Tyser
The following changes were made, primarily to bring the Marvell i2c driver in line with U-Boot's current I2C API: - Made i2c_init() globally accessible - Made i2c_read() and i2c_write() return an integer - Updated i2c_init() calls to pass in CONFIG_SYS_I2C_SLAVE in the offhand chance someone adds slave support in the future Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-19Clean up usage of icache_disable/dcache_disableKumar Gala
There is no point in disabling the icache on 7xx/74xx/86xx parts and not also flushing the icache. All callers of invalidate_l1_instruction_cache() call icache_disable() right after. Make it so icache_disable() calls invalidate_l1_instruction_cache() for us. Also, dcache_disable() already calls dcache_flush() so there is no point in the explicit calls of dcache_flush(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-10board/[A-Za-i]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-10-09Coding style cleanupWolfgang Denk
2006-07-21More code cleanupWolfgang Denk
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-01-03* Patch by Ronen Shitrit, 10 Dec 2003:wdenk
Add support for the Marvell DB64360 / DB64460 development boards * Patch by Detlev Zundel, 10 Dec 2003: fix dependency problem in examples/Makefile
