path: root/board/Marvell
2015-05-05arm: mvebu: Add Armada A38x DB-88F6820-GP board supportStefan Roese
This patch adds support for the Marvell DB-88F6820-GP Armada A38x evaluation board. Supported peripherals are: - UART - Ethernet (mvneta) - I2C - SPI (including SPI NOR flash) Please note that this board support right now only supports the main U-Boot. Without the bin_hdr integration (DDR training etc). This will be added in a few days / weeks to complete this board port. But till then this U-Boot version can be run on the target via the original Marvell U-Boot via this command: tftpboot 4000000 db-88f6820-gp/u-boot.bin;go 4000000 Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-05-05arm: mvebu: Change network init code to allow a more flexible setupStefan Roese
With the introduction of the Armada 38x support, its necessary to change the mvneta ethernet driver init call from always 4 times to a configurable value. Lets make this init call more flexible by moving the actually used devices to the config header. Additionally this patch takes care of the slightly different base addresses for the ethernet controllers on A38x. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-05arm: armada-xp: Move SoC headers to mach-mvebu/include/machStefan Roese
Move arch/arm/include/asm/arch-armada-xp/* -> arch/arm/mach-mvebu/include/mach/* Additionally the SYS_SOC is renamed from "armada-xp" to "mvebu". With this change all these files can better be shared with other, newer Mavell MVEBU SoC's. Like the upcoming Armada 38x support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-02-24ARM: remove dkb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Lei Wen <leiwen@marvell.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-06arm: db-mv784mp-gp: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the db-mv784mp-gp eval board. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-06arm: mvebu: Placeholder bin_hdr file can now be removedStefan Roese
With this patchset the Marvell bin_hdr (DDR training) code is intergrated into mainline U-Boot. We can remove the placeholder file again, which was only introduced to make U-Boot compile and link again. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2014-11-13kconfig: arm: select CPU_V7 for some new boardsMasahiro Yamada
This commit adds "select CPU_V7" for some new boards that were not covered by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). Redundant "SYS_CPU" defines and "string" directives should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27arm: db-mv784mp-gp/maxbcm Add placeholder bin_hdr file so that linking worksStefan Roese
This file should contain the bin_hdr generated by the original Marvell U-Boot implementation. As this is currently not included in this U-Boot version, we have added this placeholder, so that the U-Boot image can be generated without errors. If you have a known to be working bin_hdr for your board, then you just need to replace this text file here with the binary header and recompile U-Boot. In a few weeks, mainline U-Boot will get support to generate the bin_hdr with the DDR training code itself. By implementing this code as SPL U-Boot. Then this file will not be needed any more and will get removed. Signed-off-by: Stefan Roese <sr@denx.de>
2014-10-27PowerPC: drop some 74xx_7xx boards and related codeWolfgang Denk
The file board/Marvell/include/mv_gen_reg.h is incompatible with the GPL (see for example the "MARVELL RESERVES THE RIGHT AT ITS SOLE DISCRETION TO REQUEST THAT THIS CODE BE IMMEDIATELY RETURNED TO MARVELL" clause). As this cannot be fixed, we remove the file and all code that depends on it. Fortunately this only affects some very old boards that have long reached EOL: CPCI750 DB64360 DB64460 p3m750 p3m7448 Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: Roger Meier <r.meier@siemens.com>
2014-10-23arm: armada-xp: Add basic support for the Marvell DB-MV784MP-GP boardStefan Roese
This patch adds basic support for the Marvell DB-MV784MP-GP evaulation board. This is the first board that uses the recently created Armada XP 78460 SoC support. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org>
2014-10-23arm: kirkwood: Change naming of dram functions from km_foo() to mvebu_foo()Stefan Roese
Additionally the SDRAM address decoding register address is not hard coded in the C code any more. A define is introduced for this base address. This makes is possible to use those gpio functions from other MVEBU SoC's as well. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-23arm: marvell: Extract kirkwood gpio functions into new common file gpio.cStefan Roese
2014-10-23arm: marvell: Move arch/kirkwood.h to arch/soc.hStefan Roese
This move makes is possible to use this header not only from kirkwood platforms but from all Marvell mvebu platforms. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-06-11cosmetic: Whitespace fixVasili Galka
Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-04-17board: Marvell: delete an unused source fileMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Lei Wen <leiwen@marvell.com>
2014-01-24board: delete meaningless serial.hMasahiro Yamada
Delete some serial.h files, whole code in which is surrounded by #if 0 ... #endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-01-09kirkwood: make MPP arrays static constAlbert ARIBAUD
This saves stack and code memory for local copy, and consumes initialized data memory. For 22 of the 29 kirkwood-based boards, this results in a global saving of about 30 bytes. For 7 of them, it results in an increase of 6 to 14 bytes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-12-13env: Use getenv_yesno() more generallyJoe Hershberger
Move the getenv_yesno() to env_common.c and change most checks for 'y' or 'n' to use this helper. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-17serial: Use default_serial_puts() in driversMarek Vasut
Replace the in-place ad-hoc implementation of serial_puts() within the drivers with default_serial_puts() call. This cuts down on the code duplication quite a bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from serial driversMarek Vasut
Remove the support for not-CONFIG_SERIAL_MULTI part from serial port drivers and some board files. Since CONFIG_SERIAL_MULTI is now enabled by default, that part is a dead code. Remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: powerpc: Implement CONFIG_SERIAL_MULTI into marvell serial driverMarek Vasut
Implement support for CONFIG_SERIAL_MULTI into marvell serial driver. This driver was so far only usable directly, but this patch also adds support for the multi method. This allows using more than one serial driver alongside the marvell driver. Also, add a weak implementation of default_serial_console() returning this driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-09-03Cosmetic doc typo fixes to the kwbimage feature docsKarl O. Pinc
Signed-off-by: Karl O. Pinc <kop@meme.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-07-07kirkwood: fix calls to kirkwood_mpp_confValentin Longchamp
With the new second save argument introduced by the previous patch, all the calls to the function had to be fixed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-05-23net: Fix remaining API interface breakageJoe Hershberger
These are all the files which use the API incorrectly but did not get built using MAKEALL -a powerpc|arm. I have no compiler for them, but the remaining issues should be far less than without this patch. Any outstanding issues are left to the maintainers of boards that use these drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-22net: Remove redefinitions of net.h functionsJoe Hershberger
Some copy/pasted drivers redefine functions defined in include/net.h. Remove these so that the definitions can be changed without error. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06PPC: Drop mv6446x_eth_initialize() from net/eth.cMarek Vasut
This function was defined as an extern in net/eth.c, drop that and use standard means of calling it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-03-06PPC: Drop mv6436x_eth_initialize() from net/eth.cMarek Vasut
This function was defined as an extern in net/eth.c, drop that and use standard means of calling it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2011-12-02DB64460: Fix GCC 4.6 build warningsWolfgang Denk
Fix: db64460.c: In function 'debug_led': db64460.c:413:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_real_open': mv_eth.c:423:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_stop': mv_eth.c:641:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_xmit': mv_eth.c:717:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_receive': mv_eth.c:802:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_get_stats': mv_eth.c:901:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_update_stat': mv_eth.c:929:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c:928:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_print_stat': mv_eth.c:1010:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'eth_clear_mib_counters': mv_eth.c:2067:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'check_dimm': sdram_init.c:289:50: warning: variable 'trrd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:37: warning: variable 'tras_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:24: warning: variable 'trcd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:8: warning: variable 'trp_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:279:34: warning: variable 'devicesForErrCheck' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'setup_sdram': sdram_init.c:1255:13: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'initdram': sdram_init.c:1744:25: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c:1742:14: warning: variable 's1' set but not used [-Wunused-but-set-variable] sdram_init.c:1742:6: warning: variable 's0' set but not used [-Wunused-but-set-variable] Note: no attempt was make to clean up the mess coding style and other issues in sdram_init.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-02DB64360: Fix GCC 4.6 build warningsWolfgang Denk
Fix: db64360.c: In function 'debug_led': db64360.c:413:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_real_open': mv_eth.c:424:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_stop': mv_eth.c:642:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_xmit': mv_eth.c:718:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_receive': mv_eth.c:803:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_get_stats': mv_eth.c:902:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_update_stat': mv_eth.c:930:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c:929:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_print_stat': mv_eth.c:1011:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'eth_clear_mib_counters': mv_eth.c:2068:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'check_dimm': sdram_init.c:289:50: warning: variable 'trrd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:37: warning: variable 'tras_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:24: warning: variable 'trcd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:8: warning: variable 'trp_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:279:34: warning: variable 'devicesForErrCheck' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'setup_sdram': sdram_init.c:1256:13: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'initdram': sdram_init.c:1735:25: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c:1733:14: warning: variable 's1' set but not used [-Wunused-but-set-variable] sdram_init.c:1733:6: warning: variable 's0' set but not used [-Wunused-but-set-variable] Note: no attempt was make to clean up the mess coding style and other issues in sdram_init.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-03ARM: dreamplug: fix compilationAnatolij Gustschin
Fix build issues: mvrtc.c: In function 'rtc_get': mvrtc.c:45: warning: implicit declaration of function 'readl' mvrtc.c: In function 'rtc_set': mvrtc.c:100: warning: implicit declaration of function 'writel' dreamplug.c: In function 'board_early_init_f': dreamplug.c:43: warning: implicit declaration of function 'kw_config_gpio' dreamplug.c: In function 'board_init': dreamplug.c:108: warning: implicit declaration of function 'kw_sdram_bar' drivers/rtc/librtc.o: In function `rtc_set': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:92: undefined reference to `writel' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:103: undefined reference to `writel' drivers/rtc/librtc.o: In function `rtc_reset': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:117: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:120: undefined reference to `readl' drivers/rtc/librtc.o: In function `rtc_get': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:45: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:48: undefined reference to `readl' ... Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27GCC4.6: Add macros to mv_gen_reg.hMarek Vasut
interrupts.c: In function 'interrupt_init_cpu': interrupts.c:40: error: 'ETHERNET0_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:40: error: (Each undeclared identifier is reported only once interrupts.c:40: error: for each function it appears in.) interrupts.c:40: error: 'ETHERNET1_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:40: error: 'ETHERNET2_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET0_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET1_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET2_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-27Marvell: dkb: add mmc supportLei Wen
Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-10-27gplug: fixed build error as a result of code cleanup patchPrafulla Wadaskar
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-27ARM: kirkwood: reduce dependence of including platform fileLei Wen
For files like the drivers/serial/serial.c, it must include the platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the definition in the platform definition files. Include the platform definition file in the config file, so that it would decouple the dependence for the driver files. Signed-off-by: Lei Wen <leiwen@marvell.com>
