path: root/board/Marvell
2012-05-23net: Fix remaining API interface breakageJoe Hershberger
These are all the files which use the API incorrectly but did not get built using MAKEALL -a powerpc|arm. I have no compiler for them, but the remaining issues should be far less than without this patch. Any outstanding issues are left to the maintainers of boards that use these drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-22net: Remove redefinitions of net.h functionsJoe Hershberger
Some copy/pasted drivers redefine functions defined in include/net.h. Remove these so that the definitions can be changed without error. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06PPC: Drop mv6446x_eth_initialize() from net/eth.cMarek Vasut
This function was defined as an extern in net/eth.c, drop that and use standard means of calling it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-03-06PPC: Drop mv6436x_eth_initialize() from net/eth.cMarek Vasut
This function was defined as an extern in net/eth.c, drop that and use standard means of calling it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2011-12-02DB64460: Fix GCC 4.6 build warningsWolfgang Denk
Fix: db64460.c: In function 'debug_led': db64460.c:413:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_real_open': mv_eth.c:423:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_stop': mv_eth.c:641:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_xmit': mv_eth.c:717:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_receive': mv_eth.c:802:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_get_stats': mv_eth.c:901:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_update_stat': mv_eth.c:929:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c:928:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_print_stat': mv_eth.c:1010:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'eth_clear_mib_counters': mv_eth.c:2067:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'check_dimm': sdram_init.c:289:50: warning: variable 'trrd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:37: warning: variable 'tras_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:24: warning: variable 'trcd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:8: warning: variable 'trp_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:279:34: warning: variable 'devicesForErrCheck' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'setup_sdram': sdram_init.c:1255:13: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'initdram': sdram_init.c:1744:25: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c:1742:14: warning: variable 's1' set but not used [-Wunused-but-set-variable] sdram_init.c:1742:6: warning: variable 's0' set but not used [-Wunused-but-set-variable] Note: no attempt was make to clean up the mess coding style and other issues in sdram_init.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-02DB64360: Fix GCC 4.6 build warningsWolfgang Denk
Fix: db64360.c: In function 'debug_led': db64360.c:413:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_real_open': mv_eth.c:424:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_stop': mv_eth.c:642:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_xmit': mv_eth.c:718:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_receive': mv_eth.c:803:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_get_stats': mv_eth.c:902:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_update_stat': mv_eth.c:930:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c:929:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_print_stat': mv_eth.c:1011:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'eth_clear_mib_counters': mv_eth.c:2068:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'check_dimm': sdram_init.c:289:50: warning: variable 'trrd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:37: warning: variable 'tras_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:24: warning: variable 'trcd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:8: warning: variable 'trp_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:279:34: warning: variable 'devicesForErrCheck' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'setup_sdram': sdram_init.c:1256:13: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'initdram': sdram_init.c:1735:25: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c:1733:14: warning: variable 's1' set but not used [-Wunused-but-set-variable] sdram_init.c:1733:6: warning: variable 's0' set but not used [-Wunused-but-set-variable] Note: no attempt was make to clean up the mess coding style and other issues in sdram_init.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-03ARM: dreamplug: fix compilationAnatolij Gustschin
Fix build issues: mvrtc.c: In function 'rtc_get': mvrtc.c:45: warning: implicit declaration of function 'readl' mvrtc.c: In function 'rtc_set': mvrtc.c:100: warning: implicit declaration of function 'writel' dreamplug.c: In function 'board_early_init_f': dreamplug.c:43: warning: implicit declaration of function 'kw_config_gpio' dreamplug.c: In function 'board_init': dreamplug.c:108: warning: implicit declaration of function 'kw_sdram_bar' drivers/rtc/librtc.o: In function `rtc_set': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:92: undefined reference to `writel' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:103: undefined reference to `writel' drivers/rtc/librtc.o: In function `rtc_reset': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:117: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:120: undefined reference to `readl' drivers/rtc/librtc.o: In function `rtc_get': /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:45: undefined reference to `readl' /home/ag/u-boot/u-boot-move-new-host/u-boot-video/drivers/rtc/mvrtc.c:48: undefined reference to `readl' ... Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27GCC4.6: Add macros to mv_gen_reg.hMarek Vasut
interrupts.c: In function 'interrupt_init_cpu': interrupts.c:40: error: 'ETHERNET0_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:40: error: (Each undeclared identifier is reported only once interrupts.c:40: error: for each function it appears in.) interrupts.c:40: error: 'ETHERNET1_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:40: error: 'ETHERNET2_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET0_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET1_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET2_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-27Marvell: dkb: add mmc supportLei Wen
Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-10-27gplug: fixed build error as a result of code cleanup patchPrafulla Wadaskar
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-27ARM: kirkwood: reduce dependence of including platform fileLei Wen
For files like the drivers/serial/serial.c, it must include the platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the definition in the platform definition files. Include the platform definition file in the config file, so that it would decouple the dependence for the driver files. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-10-27ARM: armada100: reduce dependence of including platform fileLei Wen
For files like the drivers/serial/serial.c, it must include the platform file, as the CONFIG_SYS_NS16550_COM1 must reference to the definition in the platform definition files. Include the platform definition file in the config file, so that it would decouple the dependence for the driver files. Updated cpu.h to remove build errors for gplugd board (by prafulla) Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-27Armada100: Add SPI support for Marvell gplugDAjay Bhargav
This patch add SPI driver support for Marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-27dreamplug: initial board support.Jason Cooper
Copied wholeheartedly from board/Marvell/guruplug and modified to add support for SPI NOR flash. CONFIG_MACH_DREAMPLUG defined in include/configs/dreamplug.h until Linus's kernel.org tree adds it to mach-types.h. Once it trickles down, the definition can be removed from include/configs/dreamplug.h. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
2011-10-22build: add missing $(AR)->$(cmd_link_o_target) updateMike Frysinger
Seems people fixed their files to use libfoo.o, but didn't actually update the creation targets to use $(cmd_link_o_target). Update the rest of the Makefile's found with grep. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-09-30Armada100: Enable 88E3015 PHY support for GplugDAjay Bhargav
This patch adds support for 88E3015 PHY for Marvell GplugD board. This patch depends on series of patch which adds support for Marvell GuruPlug-Display. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-30Armada100: Enable Ethernet support for GplugDAjay Bhargav
This patch enables ethernet support for Marvell GplugD board. Network related commands works. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04Armada100: Add Board Support for Marvell GuruPlug-DisplayAjay Bhargav
This patch adds basic board support with DRAM and UART functionality Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-05-11Initialize second PHY on OpenRD-Client and OpenRD-UltimateClint Adams
Though the OpenRD-Base only has one gigabit Ethernet port, both the OpenRD-Client and OpenRD-Ultimate each have two. On the Ultimate, the PHY addresses are consecutive, but on the Client they are not. (based on <62a0952ce368acc725063a00a5ec680a639d6c27.1301040318.git.julian.pidancet@citrix.com> <ad0a2dc1e422698b005d6f0ceb6dd6f75a87e00a.1301040318.git.julian.pidancet@citrix.com> ) Signed-off-by: Clint Adams <clint@debian.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Julian Pidancet <julian.pidancet@citrix.com>
2011-05-11Add definitions for OpenRD-Client and OpenRD-UltimateClint Adams
2011-05-11Rename openrd_base files to openrdClint Adams
2011-04-27I2C: add i2c support for Armada100 platformLei Wen
Add i2c support to aspenite board with Armada100 soc. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-04-27I2C: add i2c support for Pantheon platformLei Wen
Add i2c support to dkb board with pantheon soc. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-21Pantheon: Add Board Support for Marvell dkb boardLei Wen
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with * Processor upto 806Mhz * LPDDR1/2 * x8/x16 SLC/MLC NAND * Footprints for eMMC & MMC x8 card With Peripherals: * Parallel LCD I/F * Audio codecs (88PM8607) * MIPI CSI-2 camera * Marvell 88W8787 802.11n/BT module * Marvell 2G/3G RF * Dual analog mics & speakers, headset jack, LED, ambient * USB2.0 HS host, OTG (mini AB) * GPIO, GPIO expander with DIP switches for easier selection * UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-12-16Armada100: Add Board Support for Marvell Aspenite-DBPrafulla Wadaskar
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with * Processor upto 1.2GHz * Parallel 1Gb x8 DDR2-1066 MHz * 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR * Footprints for eMMC/eSD NAND & MMC x8 card * 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket * SEAF memory board, subset of PISMO2 With Peripherals: * 4.3” WVGA 24-bit LCD * Audio codecs (AC97 & I2S), TSI * VGA camera * Video in via 3 RCA jacks, and HDMI type C out * Marvell 88W8688 802.11bg/BT module * GPS RF IC * Dual analog mics & speakers, headset jack, LED, ambient light sensor * USB2.0 HS host (A), OTG (micro AB) * FE PHY, PCIE Mini Card slot * GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality The patch is tested for boot from DRAM using XDB Signed-off-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-11-2774xx_7xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-28kirkwood: get rid of config.mk filesPrafulla Wadaskar
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective board config files, all Marvell kirkwood board have just a single and common entry in their config.mk files: KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg Replace the only reference to KWD_CONFIG in the top level Makefile by an equivalent setting, and remove all kirkwood config.mk files. Signed-off-by: Wolfgang Denk <wd at denx.de> Cc: Prafulla Wadaskar <prafulla at marvell.com> Cc: Siddarth Gore <gores at marvell.com> Cc: Simon Kagstrom <simon.kagstrom at netinsight.net> Cc: Heiko Schocher <hs at denx.de> Cc: Eric Cooper <ecc at cmu.edu> Acked-by: Wolfgang Denk <wd at denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-10-20Kirkwood: bugfix: broken early console messagesPrafulla Wadaskar
It has been observed that, the complete u-boot banner does not appear on the console when the system is booted from NAND/NOR/SPI flash. This patch fixes this issue on all Marvell boards by adding board_early_init_f() support Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-10-13Kirkwood: dram_init is moved to dram.cPrafulla Wadaskar
For all Kirkwood boards so far dram_init function is duplicated dram_init function is moved to dram.c and relevant code from all board specific files removed If any board needs specific dram init handling than standard one, then, a macro CONFIG_SYS_BOARD_DRAM_INIT should be defined in board config header file and the dram_init function can be put in board specific source file For ex. keymile boards Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-06-23Get rid of bogus CONFIG_SYS_BUS_HZ and CONFIG_SYS_CONFIG_BUS_CLK definitionsWolfgang Denk
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Eran Man <eran@nbase.co.il> Cc: Stefan Roese <sr@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2010-05-21bugfix: Guruplug: Use standard miiphyMahavir Jain
call to reset PHY chip. Current PHY Software Reset operation in guruplug does not poll reset bit in control register to go to 0(auto clearing) for making sure reset was successful.This patch uses standard miiphy call miiphy_reset to make sure proper PHY reset operation. Signed-off-by: Mahavir Jain <mjain@marvell.com>
2010-04-30Marvell GuruPlug Board SupportSiddarth Gore
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0 GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot References: http://www.globalscaletechnologies.com/t-guruplugdetails.aspx http://plugcomputer.org This patch is for GuruPlug Plus, but it supports Standard version as well. Signed-off-by: Siddarth Gore <gores@marvell.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-11-27sheevaplug: correct SDRAM address control registerMark Asselstine
value The SheevaPlug DevKit is shipped with 4x8 by 1Gb DDR devices in two banks for a total of 512MB of RAM. Based on this configuration the existing values for SDRAM address control register are incorrect and result in random kernel oops as memory is incorrectly accessed (while for example extracting a large tarball such as a rootfs). Based on the hardware configuration along with the supporting documentation from Marvell these are the correct values, as well this change mimics values previously used in Marvell's own u-boot git tree for the SheevaPlug. Other variants of the hardware such as the PogoPlug and TonidoPlug may have different memory configurations but to properly support those additional board directories should be maintained or a better system to support other kwb*.cfg is needed. Tested on SheevaPlug DevKit. Signed-off-by: Mark Asselstine <mark.asselstine@windriver.com>
2009-10-13Support for the OpenRD base boardSimon Kagstrom
The implementation is borrowed from the sheevaplug board and the Marvell 1.1.4 code. Unsupported (or untested) is the SD card, PCIe and SATA. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-10-13Kirkwood: mv88f6281gtw_ge: Add kwbimage build supportPrafulla Wadaskar
This patch adds kwbimage configuration file (used by mkimage utility) to support u-boot.kwb target on mv88f6281gtw_ge board. To create Kirkwood boot image to be flashed on SPI Flash, additional parameter u-boot.kwb need to be passed during make. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-10-13Kirkwood: rd6281a: Add kwbimage build supportPrafulla Wadaskar
This patch adds kwbimage configuration file (used by mkimage utility) to support u-boot.kwb target on rd6281a platform. To create Kirkwood boot image to be flashed on NAND, additional parameter u-boot.kwb need to be passed during make. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-10Kirkwood: Sheevaplug: Add kwimage configuration filePrafulla Wadaskar
