The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM
namespace do not easily transition to Kconfig. In many cases they likely
should come from the device tree instead. Move these out of CONFIG
namespace and in to CFG namespace.
The RD-AC5X-32G16HVG6HLG-A0 development board main components and
features include:
* Main 12V/54V power supply
* 270 Gbps throughput packet processor on the main board
* DDR4:
* SR1: 2GB DDR4 2400MT/S(1GB x 2 pcs ) with ECC(1GB x 1 pcs)
* SR2: 4GB DDR4 2400MT/S(2GB x 2 pcs ) with ECC(2GB x 1 pcs)
* PCB co-layout with 4GB device to support 8GB (Dual CS) requirement
* 16GB eMMC (Samsung KLMAG1JETD-B041006)
* 16MB SPI NOR(GD25Q127C)
* 32 x 1000 Base-T interfaces
* 16 x 2500 Base-T interfaces
* SR1: 88E2540*4
* SR2: 88E2580*1+88E2540*2
* Six (6) x 25G Base-R SFP28 interfaces
* One (1) x RJ-45 console connector, interfacing to the on board UART
* One (1) x USB Type-A connector, interfacing to the USB 2.0 port (0)
* One (1) x USB Type-mini B connector, interfacing to the USB 2.0 port (1)
* One (1) x RJ-45 1G Base-T Management port, interfacing to the host
port (shared with PCIe) Connected to 88E1512 Gigabit Ethernet Phy
* One (1) x Oculink port, interfacing to the PCIe port for external CPU
connection
* POE 802.3AT support on Port 1 ~ Port 32, 802.3BT support on Port 33 ~
Port 48 (Microsemi PD69208T4, PD69208M or TI TPS2388,TPS23881
solution)
* POE total power budget 780W
* LED interfaces per network port/POE
* LED interfaces (common) showing system status
* PTP TC mode Supported (Reserved M.2 connector to support BC mode)
Signed-off-by: Chris Packham <judge.packham@gmail.com>
File name with pattern u-boot-spl* is used on all places except in kwb
image for binary with SPL-only code. Combined binary with both SPL and
proper U-Boot in other places has file name pattern u-boot-with-spl*.
Make it consistent also for kwb image and rename u-boot-spl.kwb to
u-boot-with-spl.kwb as this image contains both SPL and proper U-Boot code.
Also update documentation about file name changes.
Signed-off-by: Pali Rohár <pali@kernel.org>
This patch adds a fixup function related to a PCIe FLR (Function Level
Reset) problem on the NIC23 PCIe board. This function is imported from
the Marvell Octeon 2013 U-Boot version as a (nearly) verbatim copy. It
uses the newly introduced cyclic infrastructure, so that this function
gets called every 100us, which is needed to detect this FLR issue.
Signed-off-by: Aaron Williams <awilliams@marvell.com>
I am currently maintaing the Methode uDPU and eDPU boards so add myself
as the maintainer for them.
Remove the old entry from board/Marvell/mvebu_armada-37xx/MAINTAINERS.
Signed-off-by: Robert Marko <robert.marko@sartura.hr>
In order to be able to get rid of the non-DM MDIO bus registered in
mvneta driver, we need to stop using board_network_enable() and instead
use the DM registered MDIO device to configure switch in
last_stage_init().
Signed-off-by: Marek Behún <marek.behun@nic.cz>
This patch enables the Kconfig symbols needed for full ethernet support
on the NIC23. Additionally board specific setup is done, mostly GPIOs
related to SFP / GPIO configuration. With this, ethernet can be used on
this board. Here an example of a tftp load:
=> tftp ffffffff81000000 big
Using ethernet-mac-nexus@11800e2000000 device
TFTP from server 192.168.1.5; our IP address is 192.168.1.247
Filename 'big'.
Load address: 0xffffffff81000000
Loading: ################################################## 10 MiB
9.7 MiB/s
done
Bytes transferred = 10485760 (a00000 hex)
The Globalscale Technologies Sheevaplug board has the network chip
Marvell 88E1116R. Use uclass mvgbe and the compatible driver M88E1310
driver to bring up Ethernet.
- Remove CONFIG_RESET_PHY_R symbol from all board files
- Use uclass mvgbe to bring up the network. And remove ad-hoc code.
- Enable CONFIG_PHY_MARVELL to properly configure the network.
- Miscellaneous changes: Move constants to .c file and remove header file
board/Marvell/sheevaplug/sheevaplug.h, use BIT macro, and add/cleanup
comments.
Signed-off-by: Tony Dinh <mibodhi@gmail.com>
When storing the UBoot Environment in for example EXT4,
the U-Boot build is broken for several reasons:
1. armada-385-turris-omnia-u-boot.dtsi will not allow
CONFIG_ENV_OFFSET and CONFIG_ENV_SIZE to be undefined
2. armada-37xx/board.c ft_board_setup function does not
exist if CONFIG_ENV_IS_IN_SPI_FLASH is not defined
This commit changes these files so that selecting a
different location for the environment is possible.
Signed-off-by: Rogier Stam <rogier@unrailed.org>
Reviewed-by: Pali Rohár <pali@kernel.org>
The Globalscale Technologies Dreamplug board has the network chip
- Currently, CONFIG_RESET_PHY_R symbol is used in
arch/arm/mach-kirkwood/include/mach/config.h for all Kirkwood
boards with mv8831116 PHY, with each board defines the function
reset_phy(). Undefine it for this board.
- Add board_eth_init() to use uclass mvgbe to bring up both network
port 0 and 1. And remove ad-hoc code.
- Add myself as maintainer (this board seems to be orphaned,
could not contact Jason Cooper using current email).
board/Marvell/dreamplug/dreamplug.h, cleanup comments.
Use versioned URLs for line numbers as branches are moving in the time and
use master branch for mv-ddr-marvell where is up-to-date code.
- fdt_support: Add fdt_for_each_node_by_compatible() helper macro
(Marek)
- turris_omnia: Fixup SATA or PCIe nodes at runtime in DT blob (Pali)
- pci_mvebu: Add support for Kirkwood PCIe controllers (Pali)
- SPL: More verifications for kwbimage in SPL (Pali)
- mvebu: Remove comphy_update_map() (Pali)
- Minor misc stuff
Add macro fdt_for_each_node_by_compatible() to allow iterating over
fdt nodes by compatible string.
Convert various usages of
off = fdt_node_offset_by_compatible(fdt, start, compat);
while (off > 0) {
code();
off = fdt_node_offset_by_compatible(fdt, off, compat);
and similar, to
fdt_for_each_node_by_compatible(off, fdt, start, compat)
code();
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
CONFIG_88F5182
CONFIG_BOARD_IS_OPENRD_BASE
CONFIG_BOARD_IS_OPENRD_CLIENT
CONFIG_BOARD_IS_OPENRD_ULTIMATE
CONFIG_D2NET_V2
CONFIG_FEROCEON
CONFIG_FEROCEON_88FR131
CONFIG_INETSPACE_V2
CONFIG_KW88F6192
CONFIG_KW88F6281
CONFIG_KW88F6702
CONFIG_NET2BIG_V2
CONFIG_NETSPACE_LITE_V2
CONFIG_NETSPACE_MAX_V2
CONFIG_NETSPACE_MINI_V2
CONFIG_NETSPACE_V2
CONFIG_SHEEVA_88SV131
At this point mv-plug-common.h is now only an include of mv-common.h so
remove that indirection.
Replace fdt_alloc_phandle() with subsequent fdt_set_phandle() by
fdt_create_phandle().
Cc: Aaron Williams <awilliams@marvell.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
Cc: Vladimir Oltean <vladimir.oltean@nxp.com>
Sometimes we use uchar and sometimes char for the default environment
array. By always using char, we can get rid of some explicit casts.
OF_HOSTFILE is used on sandbox configs only. Although it's pretty
unique and not causing any confusions, we are better of having simpler
config options for the DTB.
So let's replace that with the existing OF_BOARD. U-Boot would then
have only three config options for the DTB origin.
- OF_SEPARATE, build separately from U-Boot
- OF_BOARD, board specific way of providing the DTB
- OF_EMBED embedded in the u-boot binary(should not be used in production
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Since the CP1 pinctrl is not properly set in the DTS, there is no
need for setting the pinctrl by writing hardcoded values to the MPP
registers.
So, drop the code relating to that.
Fixes: 87c220d0 ("arm: mvebu: mvebu_armada-8k: Add support for initializing iEi Puzzle-M801 networking")
This board has not been converted to CONFIG_DM by the deadline.
Remove it. As this is the last armada100 platform, remove that support
as well.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
As part of the effort of making U-Boot work with the same device tree as
Linux, there is an issue with the "xfi" phy-mode. To be precise, in
Linux there was a discussion (for those who have time to read:
https://lore.kernel.org/netdev/1576768881-24971-2-git-send-email-madalin.bucur@oss.nxp.com/)
which led to a patch:
https://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next.git/commit/?id=c114574ebfdf42f826776f717c8056a00fa94881
TL;DR: "xfi" was standardized in Linux as "10gbase-r".
This patch changes the relevant occurrences in U-Boot to use "10gbase-r"
instead of "xfi" wherever applicable.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Ethernet 1 should be ethernet-controller@76000.
Change maintainer to me. Prafulla is no longer active in U-Boot community.
It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
In DM Ethernet, the old "egiga0" and 'egiga1" names are no longer valid,
so replace these with Ethernet PHY names from device tree. Also, read
Ethernet PHY address for each port from device tree.
device tree
- In DM Ethernet, the old "egiga0" name is no longer valid, so replace it
with Ethernet PHY name from device tree. Also, Ethernet PHY address
is available so read it from device tree.
Add a new 'quiet' argument to mmc_get_op_cond() function which avoids
printing error message when SD/eMMC card is not detected.
Espressobin and mx6cuboxi boards use this function for detecting presence
of eMMC and therefore it is expected and normal that eMMC does not have to
be connected. So error message "Card did not respond to voltage select!"
should be skipped in this case as it is not an error.
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Use function mmc_get_op_cond() instead of mmc_init() for detecting presence
of eMMC. Documentation for this function says that it could be used to
detect the presence of SD/eMMC when no card detect logic is available.
This function is also used by mx6cuboxi board for detecting presence of eMMC.
Ensure that 'env default -a' always set correct value to $fdtfile, even
when custom user variable is already stored in non-volatile env storage
(means that env_get("fdtfile") call returns non-NULL value).
As default value is now correctly set like if specified at compile time in
CONFIG_EXTRA_ENV_SETTINGS, there is no need to set $fdtfile explicitly via
env_set("fdtfile", ...) call.
So remove wrong skip based on env_get("fdtfile") and then also unneeded
Fixes: c4df0f6f315c ("arm: mvebu: Espressobin: Set default value for $fdtfile env variable")
The cavium,bdk node is a non-standard dt node used by the BDK and
therefore it is removed from the dt before booting Linux. Do not
require this node to exist as it won't for standard dt's.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
These boards have not been converted to CONFIG_DM_USB by the deadline
and is also missing conversion to CONFIG_DM. Remove it
Cc: Ajay Bhargav <contact@8051projects.net>
This patch adds the base support for the Marvell Octeon TX2 CN913x DB.
Only one defconfig is added with this patch. Other board variants are
available (NAND, MMC booting) and images for these boards can be
generated by following the documentation added in the included README.
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
This patch adds the base support for the Marvell Octeon TX2 CN9130 CRB.
Not all interfaces are supported fully yet.
This patch adds the basic support for the PCIe target board equipped
with the Octeon III CN2350 SoC.
This patch adds the board specific QLM/DLM init code to the Octeon 3
EBB7304 board. The configuration of each port is read from the
environment exactly as done in the 2013 U-Boot version to keep the
board and it's configuration compatible.
commit 6285efb8a118940877522c4c07bd7c64569b4f5f upstream.
the twin-die combined memory device should be treatened as X8
device and not as X16 one
Signed-off-by: Moti Buskila <motib@marvell.com>
Reviewed-by: Kostya Porotchkin <kostap@marvell.com>
[ - the default value for twin_die_combined is set to NOT_COMBINED for
all boards, as this was default behaviour prior this change ]
Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
- Merge the patch to take <asm/global_data.h> out of <common.h>
This board has not been converted to CONFIG_DM_MMC by the deadline of
v2019.04, which is almost two years ago. In addition there are other DM
migrations it is also missing. Remove it.
Cc: Chris Packham <judge.packham@gmail.com>
Acked-by: Chris Packham <judge.packham@gmail.com>
On Espressobin board are MAC addresses stored in U-Boot env area. Therefore
they are not present in default_environment[] array constructed at compile
time.
This change puts permanent MAC addresses into default_environment[] array
at board runtime. Espressobin board has enabled DEFAULT_ENV_IS_RW option
and therefore can modify this array.
This change ensure that 'env default -a' does not delete permanent MAC
addresses from Espressobin env storage area.
Acked-by: Andre Heider <a.heider@gmail.com>
On Espressobin board value for $fdtfile cannot be determined at compile
time and is calculated at board runtime code. This change uses a new option
DEFAULT_ENV_IS_RW to allow modifying default_environment[] array at runtime
and set into it correct value.
This change also ensure that 'env default -a' set correct value to $fdtfile.
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
This change extends previous commit 061c6d1b238a ("arm: mvebu: Espressobin:
Detect presence of emmc at runtime") and when emmc is not present then emmc
is removed from U-Boot DM and corresponding slot is disabled. Therefore on
Espressobin board without soldered emmc, state of emmc hw should be same as
if emmc was disabled in DTS.
Try to initialize emmc in board_late_init() and if it fails then we know
that emmc device is not connected.
This allows to use in U-Boot just one DTS file for all Espressobin variants
and also to correctly set fdtfile env variable for Linux kernel.
Tested-by: Gérald Kerma <gerald@gk2.net>
Reviewed-by: Andre Heider <a.heider@gmail.com>
Add Luka Perkov to Puzzle-M801 BOARD MAINTAINERS.
Signed-off-by: Luka Kovacic <luka.kovacic@sartura.hr>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Fix the actual board vendor and ease synching dts files from Linux.
Signed-off-by: Andre Heider <a.heider@gmail.com>
networking
Add support for the marvell,armada8040-puzzle-m801 compatible string
in the board/Marvell/mvebu_armada-8k/board.c file to initialize the
networking on iEi Puzzle-M801 board (2x CP1 1 Gb ports).
