path: root/board/Marvell/mv88f6281gtw_ge/Makefile
2009-07-18Marvell MV88F6281GTW_GE Board supportPrafulla Wadaskar
This is Marvell's 88F6281_A0 based custom board developed for wireless access point product This patch is tested for- 1. Boot from DRAM/SPI flash/NFS 2. File transfer using tftp and loadb 3. SPI flash read/write/erase 4. Booting Linux kernel and RFS from SPI flash 5. Boot from USB supported Reviewed-by: Ronen Shitrit <rshitrit@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
