path: root/board/Marvell/db64460
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2012-12-13env: Use getenv_yesno() more generallyJoe Hershberger
Move the getenv_yesno() to env_common.c and change most checks for 'y' or 'n' to use this helper. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-05-23net: Fix remaining API interface breakageJoe Hershberger
These are all the files which use the API incorrectly but did not get built using MAKEALL -a powerpc|arm. I have no compiler for them, but the remaining issues should be far less than without this patch. Any outstanding issues are left to the maintainers of boards that use these drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-22net: Remove redefinitions of net.h functionsJoe Hershberger
Some copy/pasted drivers redefine functions defined in include/net.h. Remove these so that the definitions can be changed without error. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06PPC: Drop mv6446x_eth_initialize() from net/eth.cMarek Vasut
This function was defined as an extern in net/eth.c, drop that and use standard means of calling it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2011-12-02DB64460: Fix GCC 4.6 build warningsWolfgang Denk
Fix: db64460.c: In function 'debug_led': db64460.c:413:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_real_open': mv_eth.c:423:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_stop': mv_eth.c:641:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_xmit': mv_eth.c:717:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_receive': mv_eth.c:802:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_get_stats': mv_eth.c:901:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_update_stat': mv_eth.c:929:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c:928:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64460_eth_print_stat': mv_eth.c:1010:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'eth_clear_mib_counters': mv_eth.c:2067:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'check_dimm': sdram_init.c:289:50: warning: variable 'trrd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:37: warning: variable 'tras_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:24: warning: variable 'trcd_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:289:8: warning: variable 'trp_clocks' set but not used [-Wunused-but-set-variable] sdram_init.c:279:34: warning: variable 'devicesForErrCheck' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'setup_sdram': sdram_init.c:1255:13: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c: In function 'initdram': sdram_init.c:1744:25: warning: variable 'check' set but not used [-Wunused-but-set-variable] sdram_init.c:1742:14: warning: variable 's1' set but not used [-Wunused-but-set-variable] sdram_init.c:1742:6: warning: variable 's0' set but not used [-Wunused-but-set-variable] Note: no attempt was make to clean up the mess coding style and other issues in sdram_init.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-2774xx_7xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-06-23Get rid of bogus CONFIG_SYS_BUS_HZ and CONFIG_SYS_CONFIG_BUS_CLK definitionsWolfgang Denk
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Eran Man <eran@nbase.co.il> Cc: Stefan Roese <sr@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-09asm-generic: Consolidate errno.h to asm-generic/errno.hMichal Simek
This patch use blackfin errno.h implementation which correspond Linux kernel one. MIPS implemetation is different that's why I keep it. I removed ppc_error_no.h from Marvell boards which was the same too. I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-19Clean up usage of icache_disable/dcache_disableKumar Gala
There is no point in disabling the icache on 7xx/74xx/86xx parts and not also flushing the icache. All callers of invalidate_l1_instruction_cache() call icache_disable() right after. Make it so icache_disable() calls invalidate_l1_instruction_cache() for us. Also, dcache_disable() already calls dcache_flush() so there is no point in the explicit calls of dcache_flush(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-09Coding style cleanupWolfgang Denk
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-01-03* Patch by Ronen Shitrit, 10 Dec 2003:wdenk
Add support for the Marvell DB64360 / DB64460 development boards * Patch by Detlev Zundel, 10 Dec 2003: fix dependency problem in examples/Makefile
