[trini: Fixup common/cmd_io.c]
'bool' is defined in random places. This patch consolidates them into a
single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with
true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true.
Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun <yorksun@freescale.com>
Move the getenv_yesno() to env_common.c and change most checks for
'y' or 'n' to use this helper.
Also drop a few files referring to no longer / not yet supported
boards.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Jason Jin <jason.jin@freescale.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
These are all the files which use the API incorrectly but did not get
built using MAKEALL -a powerpc|arm. I have no compiler for them, but
the remaining issues should be far less than without this patch.
Any outstanding issues are left to the maintainers of boards that use
these drivers.
Some copy/pasted drivers redefine functions
defined in include/net.h. Remove these so that
the definitions can be changed without error.
A few subsystems are using the same define "NAMESIZE". This has been
working so far because they define it to the same number. However, I
want to change the size of eth_device's NAMESIZE, so rather than tweak
the define names, simply drop references to it. Almost no one does,
and the handful that do can easily be changed to a sizeof().
This function was defined as an extern in net/eth.c, drop that and use
standard means of calling it.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Fix:
db64360.c: In function 'debug_led':
db64360.c:413:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_real_open':
mv_eth.c:424:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_stop':
mv_eth.c:642:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_xmit':
mv_eth.c:718:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_receive':
mv_eth.c:803:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_get_stats':
mv_eth.c:902:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_update_stat':
mv_eth.c:930:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
mv_eth.c:929:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'mv64360_eth_print_stat':
mv_eth.c:1011:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable]
mv_eth.c: In function 'eth_clear_mib_counters':
mv_eth.c:2068:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
sdram_init.c: In function 'check_dimm':
sdram_init.c:289:50: warning: variable 'trrd_clocks' set but not used [-Wunused-but-set-variable]
sdram_init.c:289:37: warning: variable 'tras_clocks' set but not used [-Wunused-but-set-variable]
sdram_init.c:289:24: warning: variable 'trcd_clocks' set but not used [-Wunused-but-set-variable]
sdram_init.c:289:8: warning: variable 'trp_clocks' set but not used [-Wunused-but-set-variable]
sdram_init.c:279:34: warning: variable 'devicesForErrCheck' set but not used [-Wunused-but-set-variable]
sdram_init.c: In function 'setup_sdram':
sdram_init.c:1256:13: warning: variable 'check' set but not used [-Wunused-but-set-variable]
sdram_init.c: In function 'initdram':
sdram_init.c:1735:25: warning: variable 'check' set but not used [-Wunused-but-set-variable]
sdram_init.c:1733:14: warning: variable 's1' set but not used [-Wunused-but-set-variable]
sdram_init.c:1733:6: warning: variable 's0' set but not used [-Wunused-but-set-variable]
Note: no attempt was make to clean up the mess coding style and
other issues in sdram_init.c
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Acked-by: Detlev Zundel <dzu@denx.de>
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be
redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the
bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the
funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently.
Cc: Frank Gottschling <fgottschling@eltec.de>
Cc: Eran Man <eran@nbase.co.il>
Cc: Nye Liu <nyet@zumanetworks.com>
Cc: Roy Zang <tie-fei.zang@freescale.com>
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
This patch use blackfin errno.h implementation which
correspond Linux kernel one.
MIPS implemetation is different that's why I keep it.
I removed ppc_error_no.h from Marvell boards which
was the same too.
I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians.
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Affected boards:
db64360
db64460
katmai
taihu
taishan
yucca
cpc45
cpu87
eXalion
elppc
debris
kvme080
mpc8315erdb
integratorap
ixdp425
oxc
pm826
pm828
pm854
pm856
ppmc7xx
sc3
sc520_spunk
sorcery
tqm8272
tqm85xx
utx8245
Removed initialization of the driver from net/eth.c
Also, wrapped contents of pci_eth_init() by CONFIG_PCI.
There is no point in disabling the icache on 7xx/74xx/86xx parts and not
also flushing the icache. All callers of invalidate_l1_instruction_cache()
call icache_disable() right after. Make it so icache_disable() calls
invalidate_l1_instruction_cache() for us.
Also, dcache_disable() already calls dcache_flush() so there is no point
in the explicit calls of dcache_flush().
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
Update etags build target
* Improve NetConsole support: add support for broadcast destination
address and buffered input.
* Cleanup compiler warnings for GCC 3.3.x and later
* Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
Add support for the Marvell DB64360 / DB64460 development boards
* Patch by Detlev Zundel, 10 Dec 2003:
fix dependency problem in examples/Makefile
