path: root/board/MAI/bios_emulator/scitech
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2003-03-14Add files that were forgottenLABEL_2003_03_14_2150wdenk
2002-12-07* Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120wdenk
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
Add code for AmigaOne board (preliminary merge to U-Boot, still WIP)
