2002-12-03 | * Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230 | wdenk | |
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver. | |||
2002-11-19 | * Patch by Thomas Frieden, 13 Nov 2002: | wdenk | |
Add code for AmigaOne board (preliminary merge to U-Boot, still WIP) * Patch by Jon Diekema, 12 Nov 2002: - Adding URL for IEEE OUI lookup - Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED being defined. - In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and root-on-nfs macros are designed to switch how the default boot method gets defined. |
