Signed-off-by: Jason Jin <Jason.jin@freescale.com>
The bios emulator in the MAI board can not pass compile
and have a lot of crap in it. remove it and will have a
clean and small bios emulator in the drivers directory
which can be uesed for every board.
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
