path: root/board/MAI/bios_emulator/scitech/bin/w2kddk.bat
2007-08-06Remove the bios emulator from MAI board.Jason Jin
The bios emulator in the MAI board can not pass compile and have a lot of crap in it. remove it and will have a clean and small bios emulator in the drivers directory which can be uesed for every board. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2005-07-21Fix file permissionsWolfgang Denk
