path: root/board/MAI/AmigaOneG3SE/Makefile
2002-12-07* Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120wdenk
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable
