Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
This patch enables DM_ETH for the following Kirkwood-based LaCie boards:
- d2 Network v2
- Internet Space v2
- 2Big Network v2
- Network Space v2
- Network Space Lite v2
- Network Space Max v2
- Network Space Mini v2
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
The spi0 alias is needed by the environment code to retrieve the SPI
flash. This patch adds some -u-boot.dtsi files, providing the spi0
aliases, for all the following Kirkwood-based LaCie boards:
- d2 Network v2
- Internet Space v2
- 2Big Network v2
- Network Space v2
Note that this -u-boot.dtsi files will be removed as soon as the spi0
aliases will be available in the upstream Linux dtsi files.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Move this uncommon header out of the common header.
This is a network function so let's move it into that header.
This header file is now only used by files that access internal
environment features. Drop it from various places where it is not needed.
Move env_set() over to the new header file.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
In order that we can use eth_env_* even when CONFIG_NET isn't set, move
these functions to environment code from net code.
This fixes failures such as:
board/ti/am335x/built-in.o: In function `board_late_init':
board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr'
u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr'
which caters for use cases such as:
commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment
variable")
when Ethernet is required in Linux, but not U-Boot.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
We are now using an env_ prefix for environment functions. Rename these
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Suggested-by: Wolfgang Denk <wd@denx.de>
Rename this function for consistency with env_set().
Rather than relying on common.h to provide this include, which is going
away at some point, include it explicitly in each file.
Upon further review when populating README.scrapyard, d2net_v2 is a
variant on net2big_v2 and not just an orphan config. To help in the
future also add this to board/LaCie/net2big_v2/MAINTAINERS which needed
a little consolidation anyhow.
This reverts commit 1363740e7948a8e4bee8d5adcdf0f63f7782879d.
Cc: Simon Guinot <simon.guinot@sequanux.org>
This board has not been converted to generic board by the deadline.
Remove it.
Nowadays generic CFI code properly detects the ED Mini V2's
Macronix MC29LV400CB flash chip, therefore we can drop the
CONFIG_FLASH_CFI_LEGACY option and associated settings and code.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
ED Mini V2 is based on Orion 5x which boots at fixed
address 0xFFFF0000 in NOR Flash. Place SPL there, and
switch U-Boot from .bin to .img format, stored in
NOR Flash at 0xFFF90000.
Note: this patch was tested on HW and works, i.e.
it boots U-Boot properly, but SPL console output
currently does not appear, due to GD being trashed
by arch/arm/lib/spl.c. This trashing is soon to be
removed, and then ED Mini V2 SPL console output will
become visible.
LaCie Wireless Space has no defined maintainer.
Set myself as maintainer, since I own one of these.
Additionally the SDRAM address decoding register address is not hard coded
in the C code any more. A define is introduced for this base address.
This makes is possible to use those gpio functions from other MVEBU SoC's
as well.
Tested-by: Luka Perkov <luka@openwrt.org>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
This makes is possible to use those gpio functions from other MVEBU SoC's as well.
This move makes is possible to use this header not only from kirkwood
platforms but from all Marvell mvebu platforms.
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4
(patman: RunPipe() should not pipe stdout/stderr unless asked),
Patman spits lots of "Invalid MAINTAINERS address: '-'"
error messages for patches with global changes.
It takes too long for Patman to process them.
Anyway, "M: -" does not carry any important information.
Rather, it is just like a place holder in case of assigning
a new board maintainer. Let's comment out.
This commit can be reproduced by the following command:
find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/'
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Orion5x board select menu to orion5x/Kconfig.
Move also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="orion5x").
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
move the KirkWood board select menu to kirkwood/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="kirkwood").
Acked-by: Prafulla Wadasdkar <prafulla@marvell.com>
Cc: Luka Perkov <luka@openwrt.org>
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
This patch allows to configure the net2big_v2 LEDs at startup (through
the GPIO extension bus). The front blue LED is enabled and the SATA rear
LEDs are configured to blink in relation with the SATA activity.
This patch adds support for the CPLD GPIO bus found on some LaCie boards
(as the 2Big/5Big Network v2 and the 2Big NAS). This parallel GPIO bus
exposes two registers (address and data). Each of this register is made
up of several dedicated GPIOs. An extra GPIO is used to notify the CPLD
that the registers have been updated.
Mostly this bus is used to configure the LEDs on LaCie boards.
This patch ensures minimal cooling for the net2big_v2 by automatically
starting the I2C fan (GMT G762) at low speed (2800 RPM).
Many boot image configuration files refer to the
appropriate documentation file, but these references
contain typos in the directory and file name. Fix
them. Also fix reference to doc/README.SPL file.
This saves stack and code memory for local copy, and
consumes initialized data memory. For 22 of the 29
kirkwood-based boards, this results in a global saving
of about 30 bytes. For 7 of them, it results in an
increase of 6 to 14 bytes.
This patch adds support for the LaCie boards Network Space v2 (Lite and
Mini). This two boards are derived from the Network Space v2 and a lot
of hardware caracteristics are shared.
- CPU: Marvell 88F6192 800Mhz
- SDRAM memory: 128MB DDR2 200Mhz
- 1 SATA port: internal
- Gigabit ethernet: PHY Marvell 88E1318
- Flash memory: SPI NOR 512KB (Macronix MX25L4005A)
- i2c EEPROM: 512 bytes (24C04 type)
- 2 USB2 ports (Lite only): host and host/device
- 1 push button
- 1 SATA LED (bi-color, blue and red)
The command miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr) always
returns 8 for the PHY address. It is the reset value for the PHY
Address Register. Obviously, this default value could be incorrect.
Moreover, as the PHY address is well known, there is no need to
auto-detect it.
Now, the PHY address must given as a parameter to the PHY initialization
function. Additionally this patch also fixes some aesthetic issues.
With the new second save argument introduced by the previous patch, all
the calls to the function had to be fixed.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Fix:
edminiv2.c: In function 'reset_phy':
edminiv2.c:98:2: warning: implicit declaration of function
'mv_phy_88e1116_init' [-Wimplicit-function-declaration]
Acked-by: Simon Guinot <simon.guinot@sequanux.org>
This patch groups together all the common functions for LaCie boards:
Ethernet PHY and MAC address initializations.
Moreover the configurations for LaCie Kirkwood boards are merged into
a single file: include/configs/lacie_kw.h
This patch adds support for the LaCie 2Big Network v2 board, based on
the Marvell Kirkwood 6281 SoC.
Additional information is available at:
http://lacie-nas.org/doku.php?id=2big_network_v2
Network Space (Max) v2 and Internet Space v2 boards have different
SDRAM configuration and size: respectively 256MB (DDR2 1Gb, 128Mbx8
organisation) and 128MB (DDR2 512Mb, 64Mbx8 organisation). To handle
the differences, this patch add a dedicated kwimage.cfg file for
Internet Space v2.
Additionnaly the number of SDRAM banks is fixed.
Fix compiler warnings when compiling for netspace_v2, netspace_max_v2
and inetspace_v2:
netspace_v2.c: In function 'board_early_init_f':
netspace_v2.c:37: warning: implicit declaration of function 'kw_config_gpio'
netspace_v2.c: In function 'board_init':
netspace_v2.c:86: warning: implicit declaration of function 'kw_sdram_bar'
Acked-by: Marek Vasut <marek.vasut@gmail.com>
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
This patch add support for the Network Space v2 board and parents, based
on the Marvell Kirkwood 6281 SoC. This include Network Space (Max) v2
and Internet Space v2.
http://lacie-nas.org/doku.php?id=network_space_v2
Signed-off-by: Simon Guinot <sguinot@lacie.com>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
