path: root/board/LaCie/netspace_v2/kwbimage-is2.cfg
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-03netspace_v2: fix SDRAM configurationSimon Guinot
Network Space (Max) v2 and Internet Space v2 boards have different SDRAM configuration and size: respectively 256MB (DDR2 1Gb, 128Mbx8 organisation) and 128MB (DDR2 512Mb, 64Mbx8 organisation). To handle the differences, this patch add a dedicated kwimage.cfg file for Internet Space v2. Additionnaly the number of SDRAM banks is fixed. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
