path: root/board/LaCie/edminiv2
2011-04-27Replace obsolete e-mail addressAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-10-19Merge branch 'elf_reloc'Wolfgang Denk
Conflicts: arch/arm/include/asm/config.h board/LaCie/edminiv2/config.mk board/karo/tx25/config.mk board/logicpd/imx27lite/config.mk doc/README.arm-relocation Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-13edminiv2: add support for ELF relocationsAlbert Aribaud
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-07-12edminiv2: add ethernet supportAlbert Aribaud
Add edminiv2 board support for mv_egiga. Add edminiv2 config to enable mv_egiga. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-17Add support for the LaCie ED Mini V2 boardAlbert Aribaud
This patch adds support for the LaCie ED Mini V2 product which is based on the Marvell Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
