This board is still a non-generic board.
Cc: The LEOX team <team@leox.org>
[trini: Fixup common/cmd_io.c]
A large number of boards incorrectly used getenv() in their board init
code running before relocation. In some cases this caused U-Boot to
hang when certain environment variables grew too long.
Fix the code to use getenv_r().
Cc: Stefan Roese <sr@denx.de>
Cc: Michael Schwingen <michael@schwingen.org>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Werner Pfister <Pfister_Werner@intercontrol.de>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Peter De Schrijver <p2@mind.be>
Cc: John Zhan <zhanz@sinovee.com>
Cc: Rishi Bhattacharya <rishi@ti.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
