path: root/board/CarMediaLab
2013-05-05imx: flea3: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-16mx35: Clean up lowlevel_initBenoît Thébaudeau
Clean up mx35 lowlevel_init: - Indent with tabs. - Fix comments. - Use defined values instead of literal constants. - Use defined macros instead of duplicating code. - Use macro parameters with default values instead of #define'd configs. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01mx35: Fix broken pin definitionsBenoît Thébaudeau
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mx35: Fix typo on EDIOBenoît Thébaudeau
2011-12-06MX35: flea3: changes due to hardware revision BStefano Babic
Revision B of the board uses CSD0 for the DRAM, as usual for MX3 boards. The patch fixes also some values in the U-Boot environment. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-11-03MX35: add support for flea3 boardStefano Babic
The flea3 board is a custom board by CarMediaLab used in automotive. Network (FEC), NOR, NAND and SPI are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
