path: root/board/CZ.NIC/turris_omnia
2018-12-08ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09.02Chris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-18.09 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. Specifically this syncs with commit 99d772547314 ("Bump mv_ddr to release armada-18.09.2"). The complete log of changes is best obtained from the mv-ddr-marvell.git repository but some relevant highlights are: ddr3: add missing txsdll parameter ddr3: fix tfaw timimg parameter ddr3: fix trrd timimg parameter merge ddr3 topology header file with mv_ddr_topology one mv_ddr: a38x: fix zero memory size scrubbing issue The upstream code is incorporated omitting the portions not relevant to Armada-38x and DDR3. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT -UCONFIG_A3700 -UA3900 -UA80X0 \ -UA70X0 Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-06mvebu: select boot device at SoC levelBaruch Siach
Move the gdsys Controlcenter DC specific build time kwbimage.cfg generation code into the mach-mvebu/ directory to be shared by all 32bit mvebu platforms. Remove board specific kwbimage.cfg files, and use the generated one instead. These files are all identical, with two exceptions. Clearfog and Helios4 use the sdio boot device, whereas all others use spi. Update the defconfigs for the exceptional boards to generate the same kwbimage.cfg as before. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-06mvebu: turris_omnia: use u-boot-spl-dtb.binBaruch Siach
u-boot-spl.bin and u-boot-spl-dtb.bin are identical when building the turris_omnia_defconfig. This commit makes Turris Omnia consistent with all other mvebu boards. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-07mvebu: turris_omnia: add note about i2c slave disableBaruch Siach
Code that disables the i2c slave is now in the mvtwsi i2c driver. Platform must enable DM_I2C to use that code. Add a comment in the code as a reminder for the planned DM_I2C migration of Turris Omnia. Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Baruch Siach <baruch@tkos.co.il>
2018-05-14ARM: mvebu: a38x: restore support for setting timingChris Packham
This restores support for configuring the timing mode based on the ddr_topology. This was originally implemented in commit 90bcc3d38d2b ("driver/ddr: Add support for setting timing in hws_topology_map") but was removed as part of the upstream sync. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: sync ddr training code with upstreamChris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-17.10 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. The upstream code is incorporated omitting the ddr4 and apn806 and folding the nested a38x directory up one level. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT INTER_REGS_BASE is updated to be defined as SOC_REGS_PHY_BASE. Some now empty files are removed and the ternary license is replaced with a SPDX GPL-2.0+ identifier. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2017-11-30arm: mvebu: correct comments around cas_wl/cas_lChris Packham
The order of members in struct hws_topology_map is cas_wl, cas_l. The comments in the original db-88f6820-gp.c had this wrong and have been copied to other Armada-385 based boards. Practically this hasn't made a difference since all these boards set both cas_wl and cas_l to 0 (autodetect) but if there were ever a board that did need to set these explicitly they would run into unexpected issued. Update the comments to reflect the correct order of structure members. Reported-by: Tobi Wulff <tobi.wulff@alliedtelesis.co.nz> Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-08mvebu: turris_omnia: Fix PEX vs SATA detection for board topologyMarek BehĂșn
The I2C reading in the PEX vs SATA detection code often fails on the first try. Try three times, as the code for EEPROM reading does. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-12marvell: armada385: Add the Turris Omnia boardMarek BehĂșn
The Turris Omnia is a open-source router created by CZ.NIC. The code is based on the Marvell/db-88f6820-gp by Stefan Roese with modifications from Tomas Hlavacek in the CZ.NIC turris-omnia-uboot repository, which can be found at https://gitlab.labs.nic.cz/turris/turris-omnia-uboot By default, the Turris Omnia uses btrfs as the main and only filesystem, and also loads kernel and device tree from this filesystem. Since U-Boot does not yet support btrfs, you should not flash your Turris Omnia board with this unless you know what you are doing. Signed-off-by: Tomas Hlavacek <tomas.hlavacek@nic.cz> Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 board/CZ.NIC/turris_omnia/Makefile create mode 100644 board/CZ.NIC/turris_omnia/kwbimage.cfg create mode 100644 board/CZ.NIC/turris_omnia/turris_omnia.c create mode 100644 configs/turris_omnia_defconfig create mode 100644 include/configs/turris_omnia.h Signed-off-by: Stefan Roese <sr@denx.de>
