path: root/board/BuS
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2015-09-11arm: Remove vl_ma2sc boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove eb_cpu9k2 and eb_cpu9k2_ram boardsSimon Glass
These board have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23m68k: add architecture-specific u-boot.ldsangelo@sysam.it
Add architecture-specific u-boot.lds and remove all board-specific u-boot.lds. All the .text customization that was board-specific have been moved inside the related include/configs, inside a LDS_BOARD_TEXT define. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-01-29Export redesignMartin Dorwig
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable, the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c Signed-off-by: Martin Dorwig <dorwig@tetronik.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (resending to the list since my tweaks are not quite trivial)
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2013-12-01arm926ejs, at91: add common phy_reset functionHeiko Schocher
add common phy reset code into a common function. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Jens Scharsig <esw@bus-elektronik.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Stelian Pop <stelian@popies.net> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Eric Benard <eric@eukrea.com> Cc: Markus Hubig <mhubig@imko.de> Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-01m68k: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-11-14M68K: eb_cpu5282: general update and enhanced board supportJens Scharsig (BuS Elektronik)
- update clock settings for higher perfomance - change standard baud rate to 115200 - fix flash base address - remove unused defines - add I2C support - switch form board dependent flash to cfi - remove board dependent flash code - use sdram bank 0 instead of bank 1 on boot - enable on board frame buffer instead external - remove fake mac address form config - add watchdog support - add status led support Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> [agust: fixed small style issues and build warning] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-09-03eb_cpux9k2: fix chip selectJens Scharsig
* fix chip select initialization for frame buffer, this will be increase frame buffer access speed Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm:at91-boards: remove console_init_f where unnecessaryAndreas Bießmann
A lot of at91 boards have the console_init_f in board_init. This is useless cause it was called before by generic code in lib/board.c. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Jens Scharsig <esw@bus-elektronik.de> cc: Stelian Pop <stelian@popies.net> cc: Sedji Gaouaou<sedji.gaouaou@atmel.com> cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> cc: Eric Benard <eric@eukrea.com> Tested-by: voice.shen@atmel.com Tested-by: voice.shen@atmel.com Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-08-09rename EB+MCF-EV123 to its current marketing name EB+CPU5282Jens Scharsig
* rename board directory to eb_cpu5282 * rename EB+MCF-EV123_.*config to eb_cpu5282_.*config * add Maintainer for EB+CPU5282 board * rename prompt Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-07-07add new board vl_ma2scesw@bus-elektronik.de
* add support for board VL+MA2SC * adds vl_ma2sc_config for standard NOR boot configuration * adds vl_ma2sc_ram_config for RAM load configuration Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-11-07ColdFire: The EB+MCF-EV123 boards config updateJason Jin
Update the config.mk for EB+MCF-EV123 boards according to the config change from Makefile to boards.cfg. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-10-19ColdFire: Cleanup lds files for multiple defined symbolsstany MARCEL
Lds files cleened to remove multiple defined section and modified to be compliant with --gc-sections added for ColdFire platform in a previous patch. Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Remove calls to set_timer outside arch/Graeme Russ
There is no need to use set_timer(). Replace with appropriate use of get_timer() Signed-off-by: Graeme Russ <graeme.russ@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-04eb_cpux9k2: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Jens Scharsig<js_at_ng@scharsoft.de> Tested-by: Jens Scharsig<js_at_ng@scharsoft.de> (for eb_cpux9k2 board)
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-10-19update board EB+CPUx9K2Jens Scharsig
* update to support arm reloaction * unnecessary environment variables removed Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
