path: root/board/BuS
2012-07-07add new board vl_ma2scesw@bus-elektronik.de
* add support for board VL+MA2SC * adds vl_ma2sc_config for standard NOR boot configuration * adds vl_ma2sc_ram_config for RAM load configuration Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-11-07ColdFire: The EB+MCF-EV123 boards config updateJason Jin
Update the config.mk for EB+MCF-EV123 boards according to the config change from Makefile to boards.cfg. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-10-19ColdFire: Cleanup lds files for multiple defined symbolsstany MARCEL
Lds files cleened to remove multiple defined section and modified to be compliant with --gc-sections added for ColdFire platform in a previous patch. Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Remove calls to set_timer outside arch/Graeme Russ
There is no need to use set_timer(). Replace with appropriate use of get_timer() Signed-off-by: Graeme Russ <graeme.russ@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-04eb_cpux9k2: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Jens Scharsig<js_at_ng@scharsoft.de> Tested-by: Jens Scharsig<js_at_ng@scharsoft.de> (for eb_cpux9k2 board)
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-10-19update board EB+CPUx9K2Jens Scharsig
* update to support arm reloaction * unnecessary environment variables removed Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-02-12new board (eb_cpux9k2)Jens Scharsig
* new board (eb_cpux9k2) * support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG * select via make eb_cpux9k2_config * this also demonstrates, how to use boards with AT91RM9200 cpu in at91 arch tree Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2009-07-26update the EB+MCF-EV123 board supportJens Scharsig
This patch updates the support for EB+MCF-EV123 board and needs the [PATCH 1/2 V3] new video driver for bus vcxk framebuffers * remove the board framebuffer driver * use the common bus_vcxk framebuffer driver * adds bmp support * adds splashimage support * fix serveral cosmetical errors Signed-off-by: Jens Scharsig <esw@bus-elektronik.de> [agust@denx.de: fixed some style issues before applying] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-11-03ColdFire: Remove platforms mii.c fileTsiChung Liew
Will use mcfmii.c driver in drivers/net rather than keep creating new mii.c for each future platform. Remove EB+MCF-EV123, cobra5272, idmr, M5235EVB, M5271EVB, M5272C3, M5275EVB, M5282EVB, M5329EVB, M5373EVB, M54451EVB, M54455EVB, M547xEVB, and M548xEVB's mii.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-07-14EB+MCF-EV123 board: fix coding style (alingment)Wolfgang Denk
2008-07-14EB+MCF-EV123 board: fix syntx errorWolfgang Denk
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-11Fix compile error caused by incorrect function return typeTsiChung Liew
Rename int mii_init(void) to void mii_init(void) Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-05-14Fix config files for out-of-tree buildingWolfgang Denk
Several board/<...>/config.mk files include dynamically built (by the Makefile) config files but used the wrong file name of $(TOPDIR)/board/$(BOARDDIR)/config.tmp instead if the correct $(OBJTREE)/board/$(BOARDDIR)/config.tmp The bug is nasty because the build result is correct for the (normal) in-tree builds, and because 'sinclude' is used no errors get raised even for out-of-tree build tests. But out-of-tree builds use an incomplete and thus usually incorrect configuration... Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Fix remaining CONFIG_COMMANDSJean-Christophe PLAGNIOL-VILLARD
update comments Fix coding style Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-08-16ColdFire: Update EB+MCF-EV123 platformTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2006-11-30Code cleanup.Wolfgang Denk
2006-06-10Minor code cleanup.Wolfgang Denk
2006-04-20Add MCF5282 support (without preloader)Heiko Schocher
relocate ichache_State to ram u-boot can run from internal flash Add EB+MCF-EV123 board support. Add m68k Boards to MAKEALL Patch from Jens Scharsig, 08 Aug 2005
