path: root/board/BuR
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2020-03-03board: brxre1: fix building errorsDario Binacchi
Fix building errors if CONFIG_DM_VIDEO is enabled. This is the only u-boot board that enables CONFIG_AM335X_LCD and from which I started to develop the version of the frame buffer driver that supports the driver model. Signed-off-by: Dario Binacchi <dariobin@libero.it>
2020-01-17common: Move hang() to the same header as panic()Simon Glass
At present panic() is in the vsprintf.h header file. That does not seem like an obvious choice for hang(), even though it relates to panic(). So let's put hang() in its own header. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Migrate a few more files] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move bootcount functions to their header fileSimon Glass
These don't need to be in common.h so move them out. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-03board/BuR/brppt2: initial commitHannes Schmelzer
This commit adds support for the brppt2 board. The board is based on the i.mx6 dual-lite SoC. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-08-12Merge branch '2019-08-11-ti-imports'Tom Rini
- More DaVinci updates and fixes - PCIe support on am65x - Watchdog converted to DM - Assorted other bugfixes
2019-08-12board/BuR/brsmarc1: initial commitHannes Schmelzer
This commit adds support for the B&R brsmarc1 SoM. The SoM is based on TI's AM335x SoC. Mainly vxWorks 6.9.4.x is running on the board, doing some PLC stuff on various carrier boards. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-08-11env: Move env_get_ulong() to env.hSimon Glass
Move env_get_ulong() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11env: Move env_set_ulong() to env.hSimon Glass
Move env_set_ulong() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-06-05board/BuR/common: fix detection for PSC/STM resetcontrollerHannes Schmelzer
2019-04-26board/BuR/brxre1: use common resetcontroller implementationHannes Schmelzer
The handling of regarding bootmode and early setup has been moved to central location 'common/br_resetc.c', so use this on brxre1 board. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-04-26board/BuR/brxre1: cosmetic cleanupHannes Schmelzer
- fixup coding style - drop unused 'PUSH_KEY' define Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-04-26board/BuR/common: add br resetcontoller implementationHannes Schmelzer
On many B&R boards we have a reset-controller, responsible for very early board-bringup (voltages, clocks, ...) and bootmode selection. To be ready for adding more B&R boards to source tree while avoiding duplicate code, we add the resetcontroller implementation to the common part of B&R boards. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-04-26board/BuR/common: add 'brdefaulip_setup' functionHannes Schmelzer
Many B&R boards are equipped with an I2C-EEPROM where various information can be stored. Today there is only a single byte for 'board_id' used. We write this 'board_id' into environment for later use during boot. If the value != 0xFF, meaning the byte is programmed, we modify the "brdefaultip" environment variable for setting an IP-Address based on board_id. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-04-26board/BuR/common: cosmetic: move 'overwrite_console' up to more related stuffHannes Schmelzer
2019-04-26board/BuR/common: prepare for compiling common into non AM33XX boardsHannes Schmelzer
Today the BuR common stuff is only used on AM33XX boards. In future we plan to have many other platforms than AM33XX so we have to move arch- specific #include(s) to responsible #ifdef sections. By the way we drop unneeded #include(s). Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-02-19board/BuR/brxre1: convert do DMHannes Schmelzer
This commit converts the brxre1 board to DM, for this we have todo following things: - add a devicetree-file for this board - drop all obsolete settings from board header-file - use dm_i2c_xxx calls for read/write to the resetcontroller - request gpios before operate them Serues-cc: trini@konsulko.com Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-02-09board/BuR/brppt1: drop DM_I2C_COMPATHannes Schmelzer
The TPS62517 PMIC driver has been partially converted to DM, so the legacy I2C access layer isn't needed anymore. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-07-19board/BuR/brppt1: add makerule for generating production filesHannes Schmelzer
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/brppt1: convert brppt1 boards to driver modelHannes Schmelzer
- add a devicetree for each variant (mmc, spi, nand) - drop unneeded code from board and bur/common - drop unneeded stuff from config header files - minor adaptions to be compliant with driver model (requesting gpio,..) - harmonize the commandset over all brppt1 targets Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/brppt1: implement more flexible boot processHannes Schmelzer
With this commit we do: - set the bootdelay in all brppt1 defconfigs to 0, this makes development easier, since we can break into serial console. - move CONFIG_BOOTCOMMAND from header file to defconfig - introduce b_mode variable for selecting the final boot-target. This b_mode represents the boot-switch, which can found on most b&r targets. On the brppt1 this boot-switch is derived from some gpio and the bootcounter within the RTC block, making it so possible to force a boot-target (as example for repair-case). - refactor the environment for booting new flexible way primary we want to get some bootscr.img within the mass-storage, this script then loads everything needed for the boot. For legacy reason we implement the t30lgcy#x boot targets, booting the already delivered linux-images. - make space for the cfgscr within mtdparts on brppt1_nand Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/common: refactor ft_board_setup(...)Hannes Schmelzer
On other OS, not one provided by B&R, it is not guaranteed that there are factory-settings within a devicetree. So we must not treat the absence of them as error. Further we've the fact that on different version of the device-tree files there are different namings of the factory-settings, we consider this with searching for an alternative name. changing things as following: - don't treat as error if the bootloader version cannot written into devicetree. - since the naming of the factory-settings are different in different versions of the provided device-tree we search for the alternate name "/fset" Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/brppt1: drop dead code (CONFIG_SPL_OS_BOOT)Hannes Schmelzer
The falcon mode was never used on this board, there is also no plan to use it. So drop this dead code. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/common: fix PMIC mpu-pll setupHannes Schmelzer
If a board-code calls the pmicsetup(u32 mpupll) with a mpupll value != 0 it wants to force some frequency with the value provided by mpupll. Setting up 1 GHz is wrong here. Nobody did take notice about that yet, since every board calls this function with zero. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/common: remove interface Label from summary screenHannes Schmelzer
This interface names may vary over different products, to consider this fact we replace the interface label "IF1" and "IF2" on the summary screen with some more generic wording "MAC1" and "MAC2". Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/brppt1: drop LCD-supportHannes Schmelzer
On this linux target long time ago the OS is using DRM driver for handling video output, the pre initialization of u-boot and the display summary screen is obsolete. With this patch we drop the LCD-support from thisd board. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/common: make CONFIG_LCD optionalHannes Schmelzer
Since we're going to drop LCD-support on brppt1 boards, we have to make this stuff here optional and remove the #error path. We also move out the ft_board_setup(...) from this #ifdef because there's no relationship with the LCD-code and on the other hand this is still needed in future even with LCD-support off. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR/common: drop simple-framebuffer setupHannes Schmelzer
The linux systems running on the brppt1 targets are using modern DRM drivers since long time ago. Further we are going to drop the LCD support completely on this board, so the simple-framebuffer setup becomes obsolete. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-07-19board/BuR: drop devicetree loading and lcd setup for linux-targetsHannes Schmelzer
This patch drops the lcd-screen setup, the summary screen and getting mac-addresses based on a previous loaded device-tree for linux targets. Selecting those linux target is simple, since we have only the brppt1. In detail we do: - drop the common lcd-setup code which relys on a fdt_blob - drop the common dtb loading mechanism - drop the now obsolete CONFIG_USE_FDT from board header and whitelist. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-01-11board/BuR: drop LCDC clock manipulation from board codeHannes Schmelzer
The clock selection is done now from the am335x-fb code, so there is no more need doing this in the board code. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2018-01-11board/BuR: provide real clock-frequency instead a dividerHannes Schmelzer
Actual am335x-fb implementation takes now a real clock frequency instead a divider. So this component doesn't need to know anymore some base frequency of the LCDC, we simply provide the pixel-clock frequency. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-11board: BuR: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-16board/BuR/brxre1: fix MMC bootHannes Schmelzer
since commit 'd5abcf94c7123167725fc22ace342f0d455093c1' - ti: boot: Register the MMC controllers in SPL in the same way as in u-boot MMC boot on brxre1 board is broken, with this commit we make our board working again. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-05-15mmc: replace CONFIG_GENERIC_MMC with CONFIG_MMCMasahiro Yamada
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig. We do not need two options for the same feature. Deprecate the former. This commit was generated with the sed script 's/GENERIC_MMC/MMC/' and manual fixup of drivers/mmc/Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-05board/BuR/common: incorrect check of dtbxypron.glpk@gmx.de
The logical expression to check the dtb is incorrect in load_devicetree. The problem was indicated by cppcheck. The inconsistent variable name dtppart is changed to dtbpart. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2017-03-19ti: boot: Register the MMC controllers in SPL in the same way as in u-bootJean-Jacques Hiblot
To keep a consistent MMC device mapping in SPL and in u-boot, let's register the MMC controllers the same way in u-boot and in the SPL. In terms of boot time, it doesn't hurt to register more controllers than needed because the MMC device is initialized only prior being accessed for the first time. Having the same device mapping in SPL and u-boot allows us to use the environment in SPL whatever the MMC boot device. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2016-06-24board/BuR: rename kwb board to brxre1Hannes Schmelzer
Rename B&R kwb board to brxre1 Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-24board/BuR: rename tseries board to brppt1Hannes Schmelzer
Rename B&R tseries board to brppt1 Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
