path: root/board/BuR
2015-03-28board/BuR/common: remove unused function 'blink'Hannes Petermaier
since we have possibility to write out on lcd whats going on, we don't need the gpio blink functionality anymore. Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-28board/BuR/common: move I2C initialization from common part to board-specificHannes Petermaier
At this time I2C and responsible pin-mux is setup during PMIC initialziation within common.c, this is possible because today PMIC is always connected on I2C0. In Future this will be changed, PMIC isn't anymore connected to bus0 in call cases. So we do following: - rename enable_i2c_pin_mux0 to enable_i2c_pin_mux to be generic for enabling pin-mux on different or more busses. - move the call to i2c_pin_mux and i2c_init from common.c to the specific board.c Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-17board/BuR/common: use SYS_CONSOLE_OVERWRITEHannes Petermaier
We don't want that CONSOLE is redirected to LCD upon init, we rather prefer that console is still on the serial line. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/kwb: Support modify bootcmd through reset-controllerHannes Petermaier
For some cases it is necessary to modify temporaly the bootcommand. This can be done by writing into the Scratchregister a specific value: * 0xCC - modify bootcmd "run netboot" * 0xCD - modify bootcmd "run netscript" * 0xCE - modify bootcmd "run mmcboot" the environment in flash is NOT overwritten. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/kwb: Form a bootline for vxWorksHannes Petermaier
vxWorks needs several parameters which are set by the bootloader und his environment. So we form a vxWorks bootline and pass the result to vxWorks on a predefined address. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/kwb: switch to board HW-Rev3Hannes Petermaier
The board has been redesigned, therefore we need from now other I/O Pins to mux and handle. Older boards aren't supported from now anymore. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/tseries: cosmetic changesHannes Petermaier
remove unnary '#define ETHLED_ORANGE (96+16) /* GPIO3_16 */' Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/tseries: Chg Pinmux - enable UART1 pinsHannes Petermaier
2015-03-05board/BuR/tseries: Chg pinmux - use free NAND Pins in non NAND-config as GPIOHannes Petermaier
On boards were we have no NAND-flash soldered, we want to use those free pins as regular gpio. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/tseries: Change pinmux for GPIO2_28 from GPIO to PWM-TimeroutputHannes Petermaier
2015-03-05board/BuR/tseries: Enable HW-WatchdogHannes Petermaier
2015-03-05board/BuR/common: try to setup cpsw mac-address from the devicetreeHannes Petermaier
since we have a dtb blob programmed on the board we try to setup the cpsw interface with the programmed mac. If this method fails, we fall back to the device-fuses. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Take usage of am335x LCD-DisplayHannes Petermaier
a summary screen to the lcd. Values are taken from environment and or devicetree blob. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10board/BuR: fix pinmux for MII Ethernet InterfaceHannes Petermaier
The lines COL (collision detect) and CRS (carrier sense) needs to be connected and muxed to the CPSW MAC for a proper function in half-duplex Mode of the interface. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at> Cc: Tom Rini <trini@ti.com>
2014-06-06board/BuR/tseries: cosmetic changesHannes Petermaier
Cc: trini@ti.com Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-06-06board/BuR/tseries: only run gpmc_init(...) in NAND-buildHannes Petermaier
if we have no NAND-Chip, we don't need the gpmc-controller and therefore is no need to init it. Cc: trini@ti.com Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-06-06board/BuR/tseries: Add support for using 8-bit on eMMCHannes Petermaier
2014-05-23Add board_mmc_init(...) function for init mmc1 onlyHannes Petermaier
Since B&R boards uses only MMC-Controller #1, it only wastes time if we initialize #0 first to see that there is nothing. Cc: <trini@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-03-12board/BuR/kwb: fix usage of 'i2c_set_bus_speed'Hannes Petermaier
- fix: return-value of 'i2c_set_bus_speed' was interpreted wrong Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-03-06board/BuR/common: fix phy addressesHannes Petermaier
B&R boards are using Phy Addresses 'one' and 'two', prior this was defined through #define PHYADDR 1 within a header file. Now this is addresses are given with device-driver structure. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21Add support for B&R KWB MotherboardHannes Petermaier
Adds support for Bernecker & Rainer Industrieelektronik GmbH KWB Motherboard, using TI's AM3352 SoC. Most of code is derived from TI's AM335x_EVM Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at> Cc: trini@ti.com
2014-02-21board: Add support for B&R T-Series MotherboardHannes Petermaier
Adds support for Bernecker & Rainer Industrieelektronik GmbH T-Series Motherboard, using TI's AM3352 SoC. Most of code is derived from TI's AM335x_EVM Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
