path: root/board/BuR/common
2015-06-18board/BuR/common: support timer5 for pwm-backlightHannes Petermaier
in future we support yet another b&r am335x based board, where Timer 5 is wired to backlight-driver. So we introduce a new driver-type '2' to setup timer5 instead timer6. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-28cosmetic: change Author/MAINTAINER Name from Petermaier to SchmelzerHannes Schmelzer
Since i've been married, i also have a new surname. Mr. Petermaier moved to Mr. Schmelzer. In this patch i update all files in which my (old) name is present. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-05-08board/BuR/tseries: Add simplefb supportHannes Petermaier
Since the used AM3352 SoC doesn't have GPU it isn't allways necessary to build in complete drm-stuff into linux kernel. In very small applications only we use the simple-framebuffer. So we have 2 use-cases: - device operating on drm-driver (let simplefb node disabled) - device operating on simplefb-driver (activate simplefb node and reserve mem) The decision is made by means of "simplefb" environment variable. simplefb = 0 we don't enable the (maybe) existing simplefb node and all the rest around display is up to the linux-kernel. We just disable the backlight, beceause we do not want see the flicker during take over of drm-driver. simplefb = 1 we enable the (maybe) existing simplefb node and reserve framebuffers size in memory. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-05-08board/BuR/tseries: take usage of CONFIG_LCD_ROTATIONHannes Petermaier
We take use of the new LCD_ROTATION feature. The information about how the display is rotated is taken from B&R specific (/factory-settings/rotation) information in the devicetree. The information there is stored as string (cw, ud, ccw, none) since starting support of this devices and cannot be changed, so we have to convert it into none = 0 cw = 1 ud = 2 ccw = 3 Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-04-23board/BuR/tseries: reactivate NAND-boardHannes Petermaier
The NAND-version has been become a bit orphan. Now we need to reactivate it, so bring necessary things: - loading devicetree - switch control signal to correct pins - setup pinmux - default-environment up to date. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-04-23board/BuR/common: simplify access to devicetreeHannes Petermaier
instead of polling everytime the environment, we take usage of the global gd->fdt_blob variable and check it only against NULL. Variable "dtbaddr" from environment is needed only one time on loading the devicetree within "load_devicetree()" Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-28board/BuR/common: remove unused function 'blink'Hannes Petermaier
since we have possibility to write out on lcd whats going on, we don't need the gpio blink functionality anymore. Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-28board/BuR/common: move I2C initialization from common part to board-specificHannes Petermaier
At this time I2C and responsible pin-mux is setup during PMIC initialziation within common.c, this is possible because today PMIC is always connected on I2C0. In Future this will be changed, PMIC isn't anymore connected to bus0 in call cases. So we do following: - rename enable_i2c_pin_mux0 to enable_i2c_pin_mux to be generic for enabling pin-mux on different or more busses. - move the call to i2c_pin_mux and i2c_init from common.c to the specific board.c Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-17board/BuR/common: use SYS_CONSOLE_OVERWRITEHannes Petermaier
We don't want that CONSOLE is redirected to LCD upon init, we rather prefer that console is still on the serial line. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: try to setup cpsw mac-address from the devicetreeHannes Petermaier
since we have a dtb blob programmed on the board we try to setup the cpsw interface with the programmed mac. If this method fails, we fall back to the device-fuses. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05board/BuR/common: Take usage of am335x LCD-DisplayHannes Petermaier
a summary screen to the lcd. Values are taken from environment and or devicetree blob. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-05-23Add board_mmc_init(...) function for init mmc1 onlyHannes Petermaier
Since B&R boards uses only MMC-Controller #1, it only wastes time if we initialize #0 first to see that there is nothing. Cc: <trini@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-03-06board/BuR/common: fix phy addressesHannes Petermaier
B&R boards are using Phy Addresses 'one' and 'two', prior this was defined through #define PHYADDR 1 within a header file. Now this is addresses are given with device-driver structure. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21board: Add support for B&R T-Series MotherboardHannes Petermaier
Adds support for Bernecker & Rainer Industrieelektronik GmbH T-Series Motherboard, using TI's AM3352 SoC. Most of code is derived from TI's AM335x_EVM Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
