path: root/board/Barix
2014-02-26arm: make _end compiler-generatedAlbert ARIBAUD
This prevents references to _end from generating absolute relocation records. This change is binary invariant for ARM targets. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-01arm, da85x: update for the ipam390 boardHeiko Schocher
- switch to correct ecc layout used by the RBL enable CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC - update default environment - change A2CR to correct value for UART boot mode - adapt cs3cfg timings for nand - change LED bootmode signalization Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15arm, da850: add ipam390 board supportHeiko Schocher
add the am1808 based ipam390 board from Barix. - 128MByte, DDR2, synchronous RAM 16bit databus to SDRAM interface - 128MByte, NAND Flash, 8bit databus to the NANDFlash Interface - Ethernet PHY Micrel KSZ8051R via RMII - Console on UART 0 - booting fron nand flash - spl falcon bootmode Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
