The current ae350-related defconfigs could also
support newer Andes CPU IP, so modify the names of CPU
from ax25 to andesv5, and board name from ax25-ae350 to ae350.
Signed-off-by: Leo Yu-Chi Liang <ycliang@andestech.com>
Reviewed-by: Yu Chien Peter Lin <peterlin@andestech.com>
Reviewed-by: Rick Chen <rick@andestech.com>
The L2-cache is not enabled currently, the enbale_caches() will call
the v5l2_enable() callback to enable it in SPL.
Signed-off-by: Yu Chien Peter Lin <peterlin@andestech.com>
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
Original OpenSBI (without FW_PIC) will relocate itself
from 0x1000000 to 0x0. After OpenSBI added FW_PIC codes,
it will not relocate any more and always run at 0x1000000.
Hence, it may overlap with Kernel memory region. So it is
necessary to change OpenSBI address from 0x1000000 to 0x0.
More details can refer to commit cb052d771200
("riscv: qemu: spl: Fix booting Linux kernel with OpenSBI 1.0+")
Signed-off-by: Rick Chen <rick@andestech.com>
Reviewed-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Bin Meng <bmeng@tinylab.org>
Check firmware_fdt_addr header to see if it
is a valid fdt blob.
The booting flow is SPL -> OpenSBI -> U-Boot.
The boot hart may change after OpenSBI and may not always be hart0,
so wrap the related branch instruction with M-MODE.
Current DTB setup for XIP is not valid.
There is no chance for CONFIG_SYS_FDT_BASE, the DTB address used
in XIP mode, to be returned. Fix this.
Fixes: 2e8d2f88439d ("riscv: Remove OF_PRIOR_STAGE from RISC-V boards")
The address where the device tree will be passed in to U-Boot at is now
moved to the Kconfig file. If this is user configurable, it needs to be
exposed rather than hidden, and should probably be renamed as well.
Enable OF_HAS_PRIOR_STAGE for ae350 boards with OF_BOARD
Fixes: 239d22c79520 ("fdt: Enable OF_HAS_PRIOR_STAGE for most boards with OF_BOARD")
As removal of nds32 has been ack'd for the Linux kernel, remove support
here as well.
Cc: Rick Chen <rick@andestech.com>
Move this value to the board Kconfig file.
According to ./include/linux/kconfig.h,
CONFIG_IS_ENABLED(OF_BOARD) expands to 0
when CONFIG_SPL_BUILD is defined because
there is no CONFIG_SPL_OF_BOARD.
Use #if defined instead.
OF_HOSTFILE is used on sandbox configs only. Although it's pretty
unique and not causing any confusions, we are better of having simpler
config options for the DTB.
So let's replace that with the existing OF_BOARD. U-Boot would then
have only three config options for the DTB origin.
- OF_SEPARATE, build separately from U-Boot
- OF_BOARD, board specific way of providing the DTB
- OF_EMBED embedded in the u-boot binary(should not be used in production
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
At some point back in 2018 prior_stage_fdt_address and OF_PRIOR_STAGE got
introduced, in order to support a DTB handed over by an earlier stage boo
loader. However we have another option in the Kconfig (OF_BOARD) which has
identical semantics.
On RISC-V some of the boards pick up the DTB from a1 and copy it in their
private gd_t. Apart from that they copy it to prior_stage_fdt_address, if
the Kconfig option is selected, which is unnecessary.
So let's switch the config option for those boards to OF_BOARD and define
the required board_fdt_blob_setup() for them.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
Use the new BINMAN_STANDALONE_FDT option for AE350 based SPL defconfigs,
so that binman is now used to generate u-boot.itb.
- Merge the patch to take <asm/global_data.h> out of <common.h>
addr was delcared as fdt_addr_t which is now a 64-bit address.
In a 32-bit build, this causes the following warning seen when
building ax25-ae350.c:
warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
Cast addr with uintptr_t.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Use fdtdec_get_addr_size_auto_noparent to read the "reg" property
instead of fdtdec_get_addr. This will increase the compatibility
of dtb parsing.
Acked-by: Leo Liang <ycliang@andestech.com>
Tested-by: Leo Liang <ycliang@andestech.com>
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
Fix up some style problems in flash.h while we are here.
These functions relate to memory init so move them into the init
header.
To get memory size from device tree instead of
get_ram_size(). This can avoid memory access fault
in U-Boot proper after PMP configurations in OpenSBI.
Cc: KC Lin <kclin@andestech.com>
Cc: Alan Kao <alankao@andestech.com>
This patch provides four configurations which can support U-Boot SPL
to boot from RAM or FLASH and then boot FIT image including OpenSBI
FW_DYNAMIC firmware and U-Boot proper images from RAM or MMC boot devices.
With ae350_rv[32|64]_spl_defconfigs:
U-Boot SPL will be loaded by gdb or FSBL and runs in RAM in machine mode
and then load FIT image from RAM device on AE350.
With ae350_rv[32|64]_spl_xip_defconfigs:
U-Boot SPL can be burned into SPI flash and run in flash in machine mode
and then load FIT image from SPI flash or MMC device on AE350.
Find the UCLASS_CACHE driver to configure the cache controller's
settings.
When AE350 boots from flash, use CONFIG_OF_SEPARATE instead of
CONFIG_OF_BOARD.
Also remove unused code about prior_stage_fdt_address.
And modify CONFIG_SYS_FDT_BASE as flash address.
Cc: Greentime Hu <greentime@andestech.com>
Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
Add two defconfigs to support AE350 SMP booting from flash.
Remove cpu name from the defconfig naming.
Because other cpus maybe run on AE350 platform.
So only use platfrom name in defconfig naming
will be better.
Also sync MAINTAINERS:
Rename
a25-ae350_32_defconfig as ae350_rv32_defconfig
ax25-ae350_64_defconfig as ae350_rv64_defconfig
There is no need to expose RISCV_NDS to the Kconfig menu as it is
an ax25-specific option. Introduce a dedicated Kconfig option for
the cache ops of ax25 platform and use that to guard the cache ops.
ax25-ae350 use CONFIG_OF_BOARD via a2 and CONFIG_SYS_SDRAM_BASE
to boot from ram which allow the board to override the fdt
address originally.
But after this patch
riscv: save hart ID and device tree passed by prior boot stage
It provide prior_stage_fdt_address which offer a temporary
memory address to keep the dtb address passing from loader(gdb)
to u-boot with a1.
So passing via a2 and CONFIG_SYS_SDRAM_BASE is redundant and
can be removed. And it also somehow may corrupted BBL if it
was be arranged in CONFIG_SYS_SDRAM_BASE.
In board_fdt_blob_setup()
When boting from ram:
prior_stage_fdt_address will be use to reserved dtb temporarily.
When booting from ROM:
dtb will be pre-burned in CONFIG_SYS_FDT_BASE, if it is flash base.
Or CONFIG_SYS_FDT_BASE maybe a memory map space (NOT RAM or ROM)
which is provided by HW.
Since the mach_id is not used by RISC-V, remove it.
Add smc_init() to get register base from dts and
deal with atfsmc020 controler initialzation job.
Write protect is enabled by default. So WP shall
be disabled when startup, then cfi flash can be
detected and erasing and writing can be executed.
Adp-ae3xx and adp-ag101p both do smc initilize job
in lowlevel_init.S and get register base fron
CONFIG_FTSMC020_BASE. They also can be moved those
codes to board stage. Remind them as todo jobs.
After that CONFIG_FTSMC020_BASE can be removed.
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Cc: Greentime Hu <green.hu@gmail.com>
Rename
nx25 as ax25
ae250 as ae350
nx25-ae250 as ax25-ae350
including filename, variable, string and definition.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Enable CONFIG_OF_BOAD to support delivery dtb to u-boot
at run time instead of embedded.
There are two methods to delivery dtb.
1 Pass from loader:
When u-boot boot from RAM, gdb or loader can pass dtb
via a2 to u-boot dynamically. Of course gdb or loader
shall be in charge of dtb delivery.
2 Configure CONFIG_SYS_FDT_BASE:
It can be configured as RAM or ROM base statically,
no mater u-boot boot from RAM or ROM.
If it was configured as ROM base, dtb can be burned
into ROM(spi flash) by spi driver.
Meanwhile remove CONFIG_SKIP_LOWLEVEL_INIT which is
useless in nx25-ae250 configuration.
Remove board_mmc_init() in adp-ag101p, adp-ae3xx
and nx25-ae250 boards.
Add nx25-ae250 board to do platform initializations.
Signed-off-by: Greentime Hu <green.hu@gmail.com>
AG101P/AE3XX enable ftsdc010 dm flow.
Add #include <asm/mach-types.h> to fix it.
Signed-off-by: rick <rick@andestech.com>
With a few tweaks we can avoid including these files, which are only
needed by two C files.
Support Andestech eth ftmac100 device tree flow on AG101P/AE3XX platform.
Verification:
Boot linux kernel via dhcp and bootm ok.
NDS32 # setenv bootm_size 0x2000000;setenv fdt_high 0x1f00000;
NDS32 # dhcp 0x600000 10.0.4.97:boomimage-310y-ae300-spi.bin
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 10.0.4.178 (4899 ms)
Using mac@e0100000 device
TFTP from server 10.0.4.97; our IP address is 10.0.4.178
Filename 'boomimage-310y-ae300-spi.bin'.
Load address: 0x600000
Loading: #################################################################
233.4 KiB/s
done
Bytes transferred = 13872076 (d3abcc hex)
NDS32 # dhcp 0x2000000 10.0.4.97:ae300.dtb
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 10.0.4.178 (4592 ms)
Filename 'ae300.dtb'.
Load address: 0x2000000
Loading: #
82 KiB/s
done
Bytes transferred = 2378 (94a hex)
NDS32 # bootm 0x600000 - 0x2000000
Image Name:
Created: 2017-03-22 6:52:03 UTC
Image Type: NDS32 Linux Kernel Image (uncompressed)
Data Size: 13872012 Bytes = 13.2 MiB
Load Address: 0000c000
Entry Point: 0000c000
Verifying Checksum ... OK
Booting using the fdt blob at 0x2000000
Loading Kernel Image ... OK
Loading Device Tree to 01efc000, end 01eff949 ... OK
Linux version 3.10.102-20375-gb0034c1-dirty (rick@app09)
(gcc version 4.9.3 (2016-07-06_nds32le-linux-glibc-v3_experimental) )
#293 PREEMPT Wed Mar 22 14:49:28 CST 2017
CPU: NDS32 N13, AndesCore ID(wb), CPU_VER 0x0d11103f(id 13, rev 17, cfg 4159)
Support Andestech AE3xx platform: serial, timer device tree flow.
By making dram_init_banksize() return an error code we can drop the
wrapper. Adjust this and clean up all implementations.
Remove ag101 and ag102 support
Signed-off-by: Kun-Hua Huang <kunhua@andestech.com>
Add nds32 ag101p generic board support.
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
