This board still doesn't select CONFIG_DM and seems to be umaintained.
As it makes progress on modernizing several DaVinci drivers more
difficult and the maintainer has not expressed interest in updating
it, this patch proposes to remove it.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
This merges the CRC16-CCITT headers into u-boot/crc.h to prepare for
rolling CRC16 into the hash infrastructure. Given that CRC8, CRC32
and CRC32-C already have their prototypes in a single header file, it
seems a good idea to also include CRC16-CCITT in the same.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Fix the following checkpatch issues:
CHECK: No space is necessary after a cast
\#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39:
+#define PAD_CTRL_BASE 0x800
+#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \
CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST>
\#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284:
+#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C
ERROR: space required after that ',' (ctx:VxV)
\#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446:
+#define MUX_VAL(OFFSET,VALUE)\
Cc: Raphael Assenat <raph@8d.com>
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Peter Barada <peter.barada@logicpd.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
Becuase the board select menu in arch/arm/Kconfig is too big,
move the OMAP3 board select menu to omap3/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap3
Reviewed-by: Tom Rini <trini@ti.com>
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
[trini: Fixup common/cmd_io.c]
Signed-off-by: Raphael Assenat <raph@8d.com>
[trini: Squash boards.cfg / MAINTAINERS change into main patch]
