path: root/board/8dtech
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2012-10-30eco5pk: Add new board and default configRaphael Assenat
Signed-off-by: Raphael Assenat <raph@8d.com> [trini: Squash boards.cfg / MAINTAINERS change into main patch] Signed-off-by: Tom Rini <trini@ti.com>
