Cc: Oliver Brown <obrown@adventnetworks.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Since commit 957731ed (ARM: remove broken "lpd7a40x" boards),
lh7a40x cpu and serial driver have become unused. Remove them.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Clean up mx25 lowlevel_init:
- Add comments.
- Do not use write32 repeatedly with the same value in order not to increase
code size.
- Make register values configurable.
- Use macro parameters with default values instead of literal constants.
- Use defined macros instead of duplicating code.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: John Rigby <jcrigby@gmail.com>
Cc: Matthias Weisser <weisserm@arcor.de>
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0
register is actually composed of two bit-fields: one pre-divider and one
post-divider. This patch fixes the CCM access macros and the code using them
accordingly.
Optimize mx5 lowlevel_init.S code size:
- Compute values at compile time rather than at runtime where possible.
- Assign r4 to hold the zero value rather than setting registers to 0 again and
again.
- Associate a function to setup_pll rather than expanding its large macro code
multiple times.
- Allocate constant values in section only if used.
Tested-by: Stefano Babic <sbabic@denx.de>
The MMC driver appropriate for the i.MX25 is fsl_esdhc, which has nothing to do
with mxcmmc.
Also, each eSDHC instance has a dedicated clock, so gd->sdhc_clk must be set
accordingly. This is good for the case only a single SDHC instance is used
(initialization made with fsl_esdhc_mmc_init()). A future patch will fix the
multi-instance use case (initialization made directly with
fsl_esdhc_initialize()).
Cc: Eric Bénard <eric@eukrea.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
The FEC is the only SoC Ethernet support available on i.MX25, so define
cpu_eth_init() only for it instead of returning a misleading success code.
Use the standard mxc_get_clock() instead of exporting internal functions and
using literal constant values.
mxc_get_clock(MXC_FEC_CLK) should return the IPG clock, not the AHB clock.
Also, imx_get_fecclk() was correct but reimplemented the calculation of the IPG
clock, so remove the duplicated code.
Define AHB, IPG and CSPI clocks.
Avoid possible overflow in clock calculations, and do not waste calls to lldiv()
to divide simple ulongs.
The MFN bit-field of the PLL registers represents a signed value. See the
reference manual.
The i.MX5 eSDHC clocks were considered as coming from the IPG clock although
they have dedicated clock paths.
Also, on i.MX5/6, each SDHC instance has a dedicated clock, so gd->sdhc_clk must
be set accordingly. This is good for the case only a single SDHC instance is
used (initialization made with fsl_esdhc_mmc_init()). A future patch will fix
the multi-instance use case (initialization made directly with
There are only 2 I²C instances on i.MX51, but 3 on i.MX53.
The FEC clock does not come from PLL1, but from the IPG clock. The previous code
was even inconsistent with itself, returning the IPG clock as expected for
imx_get_fecclk(), but the PLL1 clock for mxc_get_clock(MXC_FEC_CLK).
The code handling the dividers was duplicated for each possible input clock, and
this function can benefit from the newly introduced get_standard_pll_sel_clk()
function instead of duplicating this mux handling code.
This function returned 66500000 instead of the correct lp_apm clock frequency if
the CCM.CSCMR1.uart_clk_sel mux is set to 3.
This patch fixes this issue by introducing the get_standard_pll_sel_clk()
function that will be used by future patches to handle identical muxes used by
many other clocks.
This fixes the "IPG PERCLK" frequency printed by the clocks command. The issue
was that get_ipg_per_clk() used periph_clk instead of lp_apm in the case
CCM.CBCMR.perclk_lp_apm_sel is set.
It also fixes I²C support.
In the case periph_clk comes from periph_apm_clk, the latter is selected by the
CCM.CBCMR.periph_apm_sel mux, which can source the lp_apm clock from its
input ♯2. get_periph_clk() returned 0 instead of the lp_apm clock frequency in
this case.
If CCM.CCSR.lp_apm is set, the lp_apm clock is not necessarily 32768 Hz x 1024.
In that case:
- on i.MX51, this clock comes from the output of the FPM,
- on i.MX53, this clock comes from the output of PLL4.
This patch fixes the code accordingly.
This fixes config_pll_clk(), which used 0x20 instead of 0x200 for PLL4_CLOCK.
The i.MX51 has a single USB PHY clock, while the i.MX53 has two. These 3 clocks
have different clock gate control bit-fields.
The existing code was correct only for i.MX53, so this patch fixes the i.MX51
use case.
Cc: Jana Rapava <fermata7@gmail.com>
Cc: Wolfgang Grandegger <wg@denx.de>
Cc: Igor Grinberg <grinberg@compulab.co.il>
The clock gate values are 2-bit bit-fields. Hence, setting or clearing only one
of these bits like what was done is wrong and can lead to unpredictable behavior
depending on the original value of these bit-fields.
Use clock gate definitions having names showing clearly the gated clock instead
of names giving only a register field index.
Clean up the i.MX5 clock driver:
- Use readl() and writel() instead of their __raw_ counterparts.
- Use the clr/setbits_le32() family of macros rather than expanding code.
- Use accessor macros for bit-fields instead of _MASK and _OFFSET.
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of
duplicated definitions.
Cc: Jason Liu <r64343@freescale.com>
Cc: Matt Sealey <matt@genesi-usa.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
i2c didn't work on imx25 due to missing MXC_IPG_PERCLK. Now using
MXC_I2C_CLK on all imx systems using i2c.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
tested on a MCIMX257CJM4A which now reports :
CPU: Freescale i.MX25 rev1.2 at 399 MHz
Signed-off-by: Eric Bénard <eric@eukrea.com>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Register CCM_CHSCCDR (offset 0x34 in CCM) is named CCM_CHSCCDR in
reference manual, but was named chscdr in struct mxc_ccm_reg.
Add meaningful constants for each clock channels and use them for
enabling and disabling i.MX6 clocks.
Includes an update to enable/disable the IPU1 clock in
drivers/video/ipu_common to remove IMX5x register access
when used on i.MX6 as discussed in V1:
http://patchwork.ozlabs.org/patch/185129/
Add function which return CPU model and revision which can be used for
cpu detection.
Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
Boards may require a different pinmux setup for NAND than the default one.
Add a way to call into board specific code to set this up.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
The prototypes used in board files were all scattered out, which lead to
code duplication between SPL and normal U-Boot and some prototypes not actually
being used. Consolidate this in a common board header.
Secondary config for the Flash attachment.
Rename board provided gpio_config_uart() to
gpio_early_init_uart() as it does the same thing as the equally
called function provided by the uart-switch code. This allows
to simply call this function in early board init whether or not
we are building with CONFIG_UART_SWITCH defined.
Also provide a weak symbol for this function, to avoid the
need to provide this function for boards that don't need any
fixup.
This patch supersedes the earlier posted
"tegra: convert gpio_config_uart to weak symbol".
Build tested with MAKEALL -s tegra20
Common practice on Tegra 2 boards is to use the pllp_out4 FO
to generate the ULPI reference clock. For this to work we have
to override the default hardware generated output divider.
This function adds a clean way to do so.
Most Tegra boards output the ULPI reference clock on pad DEV2.
Complete the periph_id enum so that we are able to enable this
clock output circuit.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h.
Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs
that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20'
'root' file.
All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK.
patches.
Move files that are going to be common between T20 and T30 into 'tegra-common'
subdirs in AVP (arm720t), CPU (armv7), and shared (arch/arm/cpu/.) areas. Any
files that are left behind in '/tegra20' will be copied to '/tegra30' subdirs
and modified for that SoC. The 'common' files should need only minor changes.
Include files (arch/arm/include/asm/arch-tegra/tegra20) will be done in a
follow-on patch.
Builds fine w/MAKEALL -s tegra20. Checkpatch.pl is clean.
This adds the required code to set up a ULPI USB port. It is
mostly a port of the Linux ULPI setup code with some tweaks
added for more correctness, discovered along the way of
debugging this.
To use this both CONFIG_USB_ULPI and CONFIG_USB_ULPI_VIEWPORT
have to be set in the board configuration file.
EHCI interface now supports more than one controller. Wire up our usb functions
to use this new interface.
Kill off ehci-core.h
It was used to specify some static controller data. To support more than
one controller being active at any time we have to carry the controller
data ourselfes. Change the ehci interface accordingly.
NOTE: OMAP implemented the ehci stuff a bit backwards and should be fixed
to do the same thing as other platforms. But the change for now is at least
compile clean.
