For SPL it is sometimes useful to have a simple malloc() just to permit
driver model to work, in the cases where the full malloc() is not made
available by the board config.
Add driver model support while retaining the existing legacy code. This
allows the driver to support boards that have converted to driver model
as well as those that have not.
These boards all have the same GPIO arrangement, so add some common platform
data that can be used by all boards. Remove the configs which are no longer
required.
Modify this driver to support driver model, with platform data required to
determine the GPIOs that it controls.
When an MPC5200 based board is used with SPL support, the main
U-Boot needs to clear the GD (global data) struct again.
Otherwise the generic board init code in board_init_f (when
CONFIG_SYS_GENERIC_BOARD is defined) will not initialize all
GD variables correctly. Resulting in a hangup on the a4m2k
board.
The gdsys hrcon board is based on a Freescale MPC8308 SOC.
It boots from NOR-Flash, kernel and rootfs are stored on
SD-Card.
On board peripherals include:
- 1x GbE (optional)
- Lattice ECP3 FPGA connected via eLBC and PCIe
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
The code for this board supports following features:
- Boot media support: NAND flash/SD card/SPI flash
- Support LCD display (optional, disabled by default)
- Support ethernet
- Support USB mass storage
Signed-off-by: Bo Shen <voice.shen@atmel.com>
- Support ethernet
replaces the at91bootstrap code with SPL code.
make the spl image with:
./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
this writes the length of the spl image into the 6th
execption vector. This is needed from the ROM bootloader.
Reviewed-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
add support for using spl code on at91sam9260 and at91sam9g45
based boards.
[adopt Bo's change in spl.c]
- compile mpddrc ram init code also for AT91SAM9M10G45
based boards.
- in CONFIG_SAMA5D3 case, look for the ATMEL_MPDDRC_CR_DECOD_INTERLEAVED
in the cr configuration
use the configure value for computing the ba_off value
not the value from the cr register. This leaded in a
wrong ram configuration on the upcoming corvus spl board
support.
generate the boot.bin file for all atmel SoC (arm920, arm926, armv7)
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
[fix subject]
The clock source for master clock can be slow clock, main clock,
plla clock or upll clock. So, make the clock source selection
field in mckr can be configured.
We need to make sure the main clock ready field in MCFR is set
after switch to main crystal oscillator.
This moves SH_32BIT to Kconfig, and removes SH_32BIT from config
files.
The argument boot_flags of board_init_f() is not used at all in the
powerpc specific board.c init sequence. Now with the generic init
sequence, this boot_flags arg is used by board_init_f().
This patch sets the r3 register that is used to pass the boot_flags
argument from the start.S board_init_f() call to 0 prior to the function
call to avoid unknown content to end up in gd->flags.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Reviewed-by: York Sun <yorksun@freescale.com>
IFC registers can be of type Little Endian or big Endian depending upon
Freescale SoC. Here SoC defines the register type of IFC IP.
So use IFC acessor functions instead of in_be32().
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
LIODN entry for B4860/B4420 mentions USB controller as "mph"
insread of "dr". This results in PAMU not permitting bus
transactions for USB DR controller on B4860 resulting in
USB function failure. Replacing "fsl-usb2-mph" with
"fsl-usb2-dr" allows USB DR controller bus transactions
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Reviewed-by: Sethi Varun-B16395 <Varun.Sethi@freescale.com>
Reviewed-by: Sun Yusong-R58495 <yorksun@freescale.com>
NEG bit default is '1' for external MDIOs as per FMAN-v3 RM, but on some
platforms, e.g. T2080QDS, this bit is '0', which leads to MDIO failure
on XAUI PHY, so set this bit definitely to align with the RM.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
1. use Payload length check disable when enable MAC;
2. add XGMII support for setting MAC interface mode;
3. only enable auto negotiation for Non-XGMII mode;
4. return 0xffff if clause 22 is used to read 10G phy_id;
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Acked-By: Joe Hershberger <joe.hershberger@ni.com>
Add initial support for TBS2910 Matrix ARM miniPC.
Support includes MMC, Ethernet, UARTs, HDMI, USB, SATA, PCI, I2C, RTC.
Signed-off-by: Soeren Moch <smoch@web.de>
Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg>
add SUPPORT_SPL feature for iMX6 SabreSD. It need to use
mx6sabresd_spl_defconfig to compile it.
Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
Add two missing Kconfig options for Novena and drop the SPL
from the Novena config.
Cc: Sean Cross <xobs@kosagi.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Add support for the 2 ehci controllers found on the sun6i (A31) soc.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Without this the cache will only work in write-through mode, and as soon as
it is put in write-back mode things break.
Add full support for dram initialization, using a fixed clock and autodetection
of the memory organization (numbers of channels, bus-width, etc.).
This is based on dram_sun6i.c and dram.h from u-boot in the Allwinner A31 SDK,
extended with extra initialization sequences and the autodetect algorithm
from boot0.
In preparation for adding sun6i dram support.
Not used atm, for future use (e.g. PSCI).
Add clock_init_safe and clockset_pll5 functions, as these are needed for
SPL support resp. DRAM init (which is needed for SPL too).
Also add some extra clock register constant defines.
The A31 uses a new push-pull two wire interface, which features higher
transfer speeds (upto 6 MHz) in theory. While the hardware can burst 8
bytes each time, this driver will only see very little use and thus is
limited to single byte transmission only.
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
Commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs)
collected the default values of CONFIG_SYS_CPU into arch/arm/Kconfig.
This commit moves "armv8" to there for consistency.
Acked-by: Georges Savoundararadj <savoundg@gmail.com>
This commit adds "select CPU_V7" for some new boards that were not
covered by commit 2e07c249a67e
(kconfig: arm: introduce symbol for ARM CPUs).
Redundant "SYS_CPU" defines and "string" directives should be removed.
There is no board with CPU "arm_intcm".
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Precisely, these boards are SH4A rather than SH4.
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Now each board selects one of CONFIG_CPU_SH2, CONFIG_CPU_SH3,
CONFIG_CPU_SH4, so let's move CONFIG_SYS_CPU definition to
arch/sh/Kconfig.
This commit moves CONFIG_SH2, CONFIG_SH2A, CONFIG_SH3, CONFIG_SH4
to Kconfig renaming into CONFIG_CPU_SH2, CONFIG_CPU_SH2A,
CONFIG_CPU_SH3, CONFIG_CPU_SH4, respectively because
arch/sh/Kconfig of Linux uses CONFIG_CPU_SH* convention.
The current prompts were added by a conversion tool
based on board directory names when switching to Kconfig.
Use better prompts mostly taken from from arch/sh/boards/*
of Linux Kernel.
mcc200 and prs200 are old and have no maintainer. Remove the boards.
This also removes the mcc200 specific 1bpp BMP support from
common/lcd.c
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: York Sun <yorksun@freescale.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
