* 'master' of git://git.denx.de/u-boot-arm:
ARM1136: Fix cache range checks
mx6: Make pad name macro consistent with the datasheet
mx28: Fix elftosb source link in README.mx28_common
doc: README.mx28_common: Add missing entry into Contents
An empty flush_dcache_range() was added into MPC83xx and MPC85xx to
work with drivers shared with other architecture. However, it is
compiled only if USB is set, but it is required for other drivers
(FSL_ESDHC), too.
CC: Andy Fleming <afleming@gmail.com>
CC: Dirk Behme <dirk.behme@de.bosch.com>
CC: Marek Vasut <marex@denx.de>
CC: Wolfgang Denk <wd@denx.de>
Added MPC83xx version.
bad_cache_range actually returned true if the range was OK, but it was used
according to its name, which resulted in all valid dcache range invalidate/flush
operations being dropped. Hence, most DMA transfers resulted in garbage data.
This patch renames this function according to what it does, and it fixes the
interpretation of its return value by other functions. The chosen naming is the
same as for ARM926EJ-S in order to be consistent.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Use the same name as defined in the datasheet.
DSP_CLK -> DISP_CLK
Signed-off-by: Ashok Kumar Reddy Kourla <ashokkourla2000@gmail.com>
ARM: lib: Remove CONFIG_ARCH_CPU_INIT dependency
ARM: OMAP4: PANDA: Add rest of the USB module pads to essentials
arm: armv7: add compile option -mno-unaligned-access if available
arm: Fix to mistake clean the memory space
This commit does the following updates.
1. Split the common cache access from cpu.c into lib folder.
2. Rename the following cache api to adapt common.h
- dcache_flush_rang -> flush_dcache_rang
- icache_inval_range -> invalidate_icache_range
3. Add invalidate_dcache_range
Signed-off-by: Macpaul Lin <macpaul@gmail.com>
Create a weak-aliased arch_cpu_init, so that we can get rid of CONFIG_ARCH_CPU_INIT
and always call arch_cpu_init.
This way we do not need to define CONFIG_ARCH_CPU_INIT in every board file, since
arch_cpu_init() is supposed to handle common CPU level code.
Recent compiler generates unaligned memory access in armv7 default.
But current U-Boot does not allow unaligned memory access, so it causes
data abort exception.
This patch add compile option "-mno-unaligned-access" if it is available.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Tested-by: Gary Thomas <gary@mlbassoc.com>
In currently, when __bss_start is equal to __bss_end__,
The bss loop will clear all the things in memory space.
But just only when __bss_end__ greater than __bss_start__,
we do the clear bss section operation.
Signed-off-by: Zhong Hongbo <bocui107@gmail.com>
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
The bf527-ezkit boards are getting too big to fit into their reserved
flash space, so we need to use a lzma compressed logo.
Since the video driver code is very similar, add lzma compressed support
to all of the Blackfin video drivers.
* 'next' of git://git.denx.de/u-boot-video:
ipu_common: Add ldb_clk for use in parenting the pixel clock
ipu_common: Do not hardcode the ipu_clk frequency
ipu_common: Rename MXC_CCM_BASE
ipu_common: Let clk_ipu_enable/disable only run on MX51 and MX53
ipu_common: Only apply the erratum to MX51
video: Rename CONFIG_VIDEO_MX5
mx6: Allow mx6 to access the IPUv3 registers
common lcd: minor coding style changes
As suggested by Graeme Russ, move gd and bd data structrures
to BSS instead of calculating the locations around the stack
and heap.
The following platforms had their config files changed
flea3, imx31_phycore, mx35pdk, mx53ard, mx53evk, mx53smd
and mx53loco.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Adjust the IPUv3 registers, so that the IPUv3 driver can be extended for mx6 as well.
tegra: define fdt_load/fdt_high variables
tegra: enable bootz command
tegra: usb: Fix device enumeration problem of USB1
tegra: trimslice: set up serial flash pinmux
tegra: add pin_mux_spi() board initialization function
tegra: add GMC/GMD funcmux entry for SFLASH
tegra: bootcmd: start USB only when needed
tegra: bootcmd enhancements
tegra: add enterrcm command
tegra: enable CONFIG_ENV_VARS_UBOOT_CONFIG
Add env vars describing U-Boot target board
tegra: usb: fix wrong error check
tegra: add ULPI on USB2 funcmux entry
tegra: fix leftover CONFIG_TEGRA2_MMC & _SPI build switches
tegra: Add Tamonten Evaluation Carrier support
tegra: Use SD write-protect GPIO on Tamonten
tegra: Implement gpio_early_init() on Tamonten
tegra: Allow boards to perform early GPIO setup
tegra: plutux: Add device tree support
tegra: medcom: Add device tree support
tegra: Rework Tamonten support
beagle: add eeprom expansion board info for bct brettl4
Fixed the compiler warning message.
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
* 'master' of git://git.denx.de/u-boot-usb:
CONFIG: EXYNOS5: USB: Enable USB 2.0 on smdk5250
EXYNOS5: USB: Fix incorrect USB base addresses
EXYNOS: Add power Enable/Disable for USB-EHCI
USB: EXYNOS: Set USB 2.0 HOST Link mode
EXYNOS5: Add structure for PMU registers
EXYNOS5: Fix system register structure
USB: EXYNOS: Incorporate EHCI review comments
A known hardware issue of USB1 port where bit 1 (connect status
change) of PORTSC register will be set after issuing Port Reset
(like "usb reset" in u-boot command line).
This will be treated as an error and stops later device enumeration.
Therefore we clear that bit after Port Reset in order to proceed
Signed-off-by: Jim Lin <jilin@nvidia.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This is used on TrimSlice.
Tegra's boot ROM supports a mode whereby code may be downloaded and flash
programmed over a USB connection. On dev boards, this is typically entered
by holding down a "force recovery" button and resetting the CPU. However,
not all boards have such a button (one example is the Compulab Trimslice),
so a method to enter RCM from software is useful.
This change implements the command "enterrcm" to do this, and enables it
for all Tegra boards by default. Even on boards other than Trimslice,
controlling this over a UART may be useful, e.g. to allow simple remote
control without the need for mechanical button actuators, or hooking up
relays/... to the button.
loop_count runs down from 10000, so the correct condition to error out
is ==0.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
CC: Stephen Warren <swarren@wwwdotorg.org>
CC: Tom Warren <twarren.nvidia@gmail.com>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
This is needed as a prerequisite for Tegra USB ULPI support
within U-Boot.
CC: Tom Warren <twarren@nvidia.com>
This patch corrects the base addresses for USB_PHY and USB_OTG.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Acked-by: Chander Kashyap <chander.kashyap@linaro.org>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
This patch adds functions to enable/disable the power of USB
host controller for EXYNOS5.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
This patch adds a function to set usb host mode to USB 2.0 HOST Link
for EXYNOS5
This patch adds power mananagement registers structure for exynos5 SoC.
This patch corrects the SYSREG structure.
We have removed the sysreg.h added in the previous patchset
version as the sysreg structure is already defined in system.h.
This patch incorates the review comments given by Minkyu Kang for
EHCI support on EXYNOS
when -O0"
This reverts commit fa042186b932e9b9ee9a2fd8a04a3acf7c70d224.
It causes build warnings like this:
cpu.c:48:1: warning: -fstack-usage not supported for this target
[enabled by default]
* 'master' of git://git.denx.de/u-boot-arm: (212 commits)
ARM: cache: Move the cp15 CR register read before flushing the cache.
ARM: introduce arch_early_init_r()
PXA: Enable CONFIG_PREBOOT on zipitz2
ARM: mx28: Remove CONFIG_ARCH_CPU_INIT
No need to define CONFIG_ARCH_CPU_INIT.
add new board vl_ma2sc
MTD: SPEAr SMI: Add write support for length < 4 bytes
i2c: designware_i2c.c: Add support for the "i2c probe" command
rtc/m41t62: Add support for M41T82 with HT (Halt Update)
SPL: ARM: spear: Add SPL support for SPEAr600 platform
Makefile: Add u-boot.spr build target (SPEAr)
SPL: ARM: spear: Remove some objects from SPL build
SPL: lib/Makefile: Add crc32.c to SPL build
SPL: common/Makefile: Add image.c to SPL build
arm: Don't use printf() in SPL builds
GPIO: Add SPEAr GPIO driver
net: Multiple updates/enhancements to designware.c
cleanup/SPEAr: Define configuration flags more elegantly
cleanup/SPEAr: Remove unnecessary parenthesis
SPEAr: Correct SoC ID offset in misc configuration space
SPEAr: explicitly select clk src for UART
SPEAr: Remove CONFIG_MTD_NAND_VERIFY_WRITE to speed up NAND access
SPEAr: Enable ONFI nand flash detection for spear3xx and 6xx and evb
SPEAr: Enable CONFIG_SYS_FLASH_EMPTY_INFO macro
SPEAr: Correct the definition of CONFIG_SYS_MONITOR_BASE
SPEAr: Enable CONFIG_SYS_FLASH_PROTECTION
SPEAr: Enable dcache for fast file transfer
SPEAr: Enable autoneg for ethernet
SPEAr: Enable udc and usb-console support only for usbtty configuration
SPEAr: Enable usb device high speed support
SPEAr: Initialize SNOR in early_board_init_f
SPEAr: Change the default environment variables
SPEAr: Remove unused flag (CONFIG_SYS_HZ_CLOCK)
SPEAr: Add configuration options for spear3xx and spear6xx boards
SPEAr: Add basic arch related support for SPEAr SoCs
SPEAr: Add interface information in initialization
SPEAr: Add macb driver support for spear310 and spear320
SPEAr: Configure network support for spear SoCs
SPEAr: Place ethaddr write and read within CONFIG_CMD_NET
SPEAr: Eliminate dependency on Xloader table
SPEAr: Fix ARM relocation support
st_smi: Fixed page size for Winbond W25Q128FV flash
st_smi: Change timeout loop implementation
st_smi: Fix bug in flash_print_info()
st_smi: Change the flash probing method
st_smi: Removed no needed dependency on ST_M25Pxx_ID
st_smi: Fix smi read status
st_smi: Move status register read before modifying ctrl register
st_smi: Read status until timeout happens
st_smi: Enhance the error handling
st_smi: Change SMI timeout values
st_smi: Return error in case TFF is not set
st_smi: Add support for SPEAr SMI driver
mtd/NAND: Remove obsolete SPEAr specific NAND drivers
SPEAr: Configure FSMC driver for NAND interface
mtd/NAND: Add FSMC driver support
arm/km: remove calls to kw_gpio_* in board_early_init_f
arm/km: add implementation for read_dip_switch
arm/km: support the 2 PCIe fpga resets
arm/km: skip FPGA config when already configured
arm/km: redefine piggy 4 reg names to avoid conflicts
arm/km: cleanup km_kirkwood boards
arm/km: enable BOCO2 FPGA download support
arm/km: remove portl2.h and use km_kirkwood instead
arm/km: convert mgcoge3un target to km_kirkwood
arm/km: add kmcoge5un board support
arm/km: add kmnusa board support
arm: bugfix: save_boot_params_default accesses uninitalized stack when -O0
cm-t35: fix incorrect NAND_ECC layout selection
ARM: OMAP4/5: Do not configure non essential pads, clocks, dplls.
ARM: OMAP4/5: Move USB pads to essential list.
ARM: OMAP4/5: Move USB clocks to essential group.
ARM: OMAP4/5: Move gpmc clocks to essential group.
ARM: OMAP4+: Move external phy initialisations to arch specific place.
omap4: Use a smaller M,N couple for IVA DPLL
da850/omap-l138: Enable auto negotiation in RMII mode
omap: am33xx: accomodate input clocks other than 24 Mhz
omap: emif: fix bug in manufacturer code test
omap: emif: deal with rams that return duplicate mr data on all byte lanes
OMAP4+: Force DDR in self-refresh after warm reset
OMAP4+: Handle sdram init after warm reset
ARM: OMAP3+: Detect reset type
arm: bugfix: Move vector table before jumping relocated code
Kirkwood: Add support for Ka-Ro TK71
arm/km: use spi claim bus to switch between SPI and NAND
arm/kirkwood: protect the ENV_SPI #defines
ARM: don't probe PHY address for LaCie boards
lacie_kw: fix CONFIG_SYS_KWD_CONFIG for inetspace_v2
lacie_kw: fix SDRAM banks number for net2big_v2
Kirkwood: add lschlv2 and lsxhl board support
net: add helper to generate random mac address
net: use common rand()/srand() functions
lib: add rand() function
kwboot: boot kirkwood SoCs over a serial link
kw_spi: add weak functions board_spi_claim/release_bus
kw_spi: support spi_claim/release_bus functions
kw_spi: backup and reset the MPP of the chosen CS pin
kirkwood: fix calls to kirkwood_mpp_conf
kirkwood: add save functionality kirkwood_mpp_conf function
km_arm: use filesize for erase in update command
arm/km: enable mii cmd
arm/km: remove CONFIG_RESET_PHY_R
arm/km: change maintainer for mgcoge3un
arm/km: fix wrong comment in SDRAM config for mgcoge3un
arm/km: use ARRAY_SIZE macro
arm/km: rename CONFIG option CONFIG_KM_DEF_ENV_UPDATE
arm/km: add piggy mac adress offset for mgcoge3un
arm/km: add board type to boards.cfg
AT91SAM9*: Change kernel address in dataflash to match u-boot's size
ATMEL/PIO: Enable new feature of PIO on Atmel device
ehci-atmel: fix compiler warning
AT91: at91sam9m10g45ek : Enable EHCI instead OHCI
Atmel : usb : add EHCI driver for Atmel SoC
Fix: AT91SAM9263 nor flash usage
Fix: broken boot message at serial line on AT91SAM9263-EK board
i.MX6 USDHC: Use the ESDHC clock
mx28evk: Fix boot by adjusting HW_DRAM_CTL29 register
i.MX28: Add function to adjust memory parameters
mx28evk: Fix PSWITCH key position
mx53smd: Remove CONFIG_SYS_I2C_SLAVE definition
mx53loco: Remove CONFIG_SYS_I2C_SLAVE definition
mx53evk: Remove CONFIG_SYS_I2C_SLAVE definition
mx53ard: Remove CONFIG_SYS_I2C_SLAVE definition
mx35pdk: Remove CONFIG_SYS_I2C_SLAVE definition
imx31_phycore: Remove CONFIG_SYS_I2C_SLAVE definition
mx53ard: Remove unused CONFIG_MII_GASKET
mx6: Avoid writing to read-only bits in imximage.cfg
m28evk: use same notation to alloc the 128kB stack
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/mpc85xx: Fix Handling the lack of L2 cache on P2040/P2040E
powerpc/mpc85xx: Workaround for erratum CPU_A011
powerpc/mpc85xx: Ignore E bit for SVR_SOC_VER()
powerpc/P4080: Check SVR for CPU22 workaround
lib/powerpc: addrmap_phys_to_virt() should return a pointer
powerpc/85xx: clean up P1022DS board configuration header file
powerpc/85xx: fdt_set_phy_handle() should return an error code
powerpc/85xx: minor clean-ups to the P2020DS board header file
powerpc/p1010rdb: add readme document for p1010rdb
powerpc/mpc85xx:NAND_SPL:Avoid IFC/eLBC Base address setting
powerpc/mpc85xx:Add debugger support for e500v2 SoC
powerpc/85xx:Fix NAND code base to support debugger
powerpc/85xx:Make debug exception vector accessible
powerpc/85xx:Fix MSR[DE] bit in MSR to support debugger
PATCH 1/4][v4] doc:Add documentation for e500 external debugger support
powerpc/p1010rdb: update mux config of p1010rdb board
powerpc/mpc85xx:Add BSC9131 RDB Support
powerpc/mpc85xx:Add BSC9131/BSC9130/BSC9231 Processor Support
powerpc/85xx: Add USB device-tree fixup for various platforms
The following is the cleanup sequence in arch/arm/cpu/armv7/cpu.c
int cleanup_before_linux(void)
dcache_disable();
v7_outer_cache_disable();
invalidate_dcache_all();
1) invalidate_dcache_all call expects that all the caches has been
flushed, invalidated and there are no dirty entries prior to its
execution. In the above sequence dcache_disable() flushes, invalidates
the caches and turns off the mmu. But after it cleanups the cache
and before the mmu is disabled there is a cp_delay() function which
has STR instruction. On certain cores like the cortex-a15, cache hit
and a write can happen to a cache line even when the dcache is
disabled. So the above mentioned STR instruction creates a dirty entry
after cleaning. The mmu gets disabled after this.
2) invalidate_dcache_all invalidates the cache lines. Again on
cores like cortex-a15, invalidate instruction flushes the dirty
line as well. So some times the dirty line from sequence 1
can corrupt the memory resulting in a crash.
Fixing this by moving the get_cr() and cp_delay() calls before
cleaning up the cache, thus avoiding the dirty entry.
Signed-off-by: R Sricharan <r.sricharan@ti.com>
Introduce arch_early_init_r() function, which can be useful for doing
early initialization after relocation has happened.
All mx28 based boards should use arch_cpu_init().
All mx6 based boards should use arch_cpu_init().
This patch adds SPL support for SPEAr600. Currently only SNOR
(Serial NOR) flash support is included. Other boot devices
(NAND, MMC, USB ...) may be added with later patches.
Tested on the STM SPEAr600 evaluation and x600 SPEAr600 boards.
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
raise() likes to call printf() if it is available, but in SPL builds it
either is not available, or adds a large chunk to the resulting image
size.
So don't call it even if it is available.
This change reduces SPL size from 10KB to 6.3KB on hawkboard, for
example, using generic relocation.
Tested on x600 (SPEAr600).
In SPEAr configuration files, unnecessary paranthesis are used in some
\#defines. Remove them as they serve no purpose
Signed-off-by: Amit Virdi <amit.virdi@st.com>
SoC Core ID offset is 0x30 in miscellaneous configuration address
space. It was wrongly mentioned as periph2 clk enable.
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
UART in u-boot intends to run on 48MHz clock supplied by USB PLL.
Explicitly select the intended clock source.
Earlier, architecture specific init code was mixed with board initialization
code in board/spear/... This patch updates architecture support for SPEAr in
latest u-boot and prints the SoC information.
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
SPEAr310 and SPEAr320 SoCs have an extra ethernet controller. The
driver for this device is already supported by u-boot, so configuring
board configuration file and defining base addresses etc to make use
of the common driver
Xloader table was used primarily to inform u-boot about the DDR size. However,
now the ddr size is calculated at runtime which eliminates any need for the
Xloader table. So removing this unnecessary code.
SMI is the serial memory interface controller provided by ST.
Earlier, a driver exists in the u-boot source code for the SMI IP. However, it
was specific to spear platforms. This commit converts the same driver to a more
generic driver. As a result, the driver files are renamed to st_smi.c and
st_smi.h and moved into drivers/mtd folder for reusability by other platforms
using smi controller peripheral.
Since, SPEAr platform uses generic FSMC driver now, so spear specific files
drivers/mtd/nand/spr_nand.c, arch/arm/include/asm/arch-spear/spr_nand.h are
removed
Acked-by: Scott Wood <scottwood@freescale.com>
Since FSMC is a standard IP and it supports different memory interfaces, it
is supported independent of spear platform and spear is configured to use that
driver for interfacing with the NAND device
save_boot_params_default() in cpu.c accesses uninitialized stack area
when it compiled with -O0 (not optimized).
Acked-by: Tom Rini <trini@ti.com>
USB clocks will be required for fastboot, tftp
related functionalities. Move these clocks to
essential group inorder to have the functionality
working when non-essential clocks are not enabled.
